Fitting A Aldon 100Ay-I Distributor
6 replies to this topic
#1 cumbriantim
cumbriantim
  • 11 posts
Posted 21 November 2014 - 09:43 AM
I have been on with rebuilding my 1275 A series engine with few tuning mods,I was considering fitting a Aldon 100AY-I electronic ignitor distributor,
http://www.aldonauto...T_ID=41&P_ID=99
I was wondering if there worth the expense of fitting or just going for a cheaper electronic ignition distributor?
http://www.ebay.co.u...=STRK:MEBIDX:IT
The engine is now a 1293 with 11 stud 12g1805 cooper head with a reface and polished ports and chambers.
Lightened flywheel and back plate and a three ring cam,think there a 266/270 fast road duration?
I also have put 1.5 roller rockers and twin 1 1/2 su's.
Is there a vast improvement from fitting the Aldon distributor that justifies the expense????
Any experience with this or advise before I make the purchase would be welcome.
#2 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 21 November 2014 - 05:42 PM
Standard distributor curve wont cut it and you'll b far better off to getting a Aldon yellow to rep the mods done, if your using the car on the road get the Aldon with a Vacuum advance thats a must for light throttle running, improved torque crusing and improved mpg
#3 cumbriantim
cumbriantim
  • 11 posts
Posted 21 November 2014 - 08:06 PM
Cheers,Is there cheaper alternatives to the Aldon one?
#4 carbon
carbon
  • 2,590 posts
Posted 21 November 2014 - 08:29 PM
A cheaper option is to stick with points and rebuild your standard Lucas dizzy with modified advance curve. But this can take quite a bit of setting up to get anywhere near right, and also depends on what mechanical advance you have in current dizzy.
If cam has 3 rings then likely to be 731 profile 268/268. Depending on CR you are likely to need quite a bit of static / idle advance as you are using 1.5 rockers. This is where getting dizzy settings right can take quite a lot of effort...
#5 mk1leg
mk1leg
  • 9,343 posts
Posted 21 November 2014 - 10:51 PM
get yourself a 123 dizzy this has 16 pre programed curves......but it works....... :highfive:
#6 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 21 November 2014 - 11:56 PM
Or give H&H Ignitions a ring Tel. 01384 261500
They have done a few for me at less then £50 with postage
#7 Dusky
Dusky
  • 5,322 posts
Posted 22 November 2014 - 08:28 AM
AC Dodd did mine :)
