HELP mini 1275gt
8 replies to this topic
#1 blister
blister
  • 1,008 posts
Posted 07 July 2006 - 03:26 PM
i have just purchased a mini 1275gt and a weber 45 carb just wondering will it make a lot of difference to the speed and what else do i need to get the full potentail out of that carb
#2 jif2006
jif2006
  • 622 posts
Posted 07 July 2006 - 03:41 PM
Yeah will make some difference to your GT probably best to get a stage 1 exhaust an air filter along with the webber .
Bradders...
#3 blister
blister
  • 1,008 posts
Posted 07 July 2006 - 03:59 PM
yes i was intending on gettin an exhaust but it doesnt say anything about what stage it is could you help me
http://www.minisport...er-product.html
the carbon fibre one
#4 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 07 July 2006 - 04:03 PM
All I can see it doing to an almost standard engine is use more fuel with very little increase in performance, it certainly wont be noticeble in the lower revs.
Sorry to rain on your parade, but stick with the SU until you have modded the engine to the point that it would benefit from the Webber. It still will use gallons more fuel though.
The stage one kit is a very good place to start.
#5 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 07 July 2006 - 04:05 PM
Ignore that, there's no such thing as a stage 1 exhaust. Like Sprocket says, it's a stage 1 kit you need.
To get the best out of that carb you need to re-engineer your entire engine and do a lot of cutting and welding to the bodyshell, then find some kind of new dashboard that covers the mess you've made on the inside. A new carb is pretty much the last thing yo need to be thinking about when tuning a car, there's lots more useful things you can do to an engine first.
Edited by Dan, 07 July 2006 - 04:06 PM.
#6 blister
blister
  • 1,008 posts
Posted 07 July 2006 - 05:17 PM
what d0 u mean by re engerirner the engine
#7 blister
blister
  • 1,008 posts
Posted 07 July 2006 - 07:10 PM
so what gives more performance 2 su carbs "the best for 1275 " or 1 webber carb what gives more acceleration and bhp
#8 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 07 July 2006 - 10:09 PM
Carbs don't give an engine it's power. The state of the engine's overall tune is what determines how thermally efficient the engine is, the carb should then be chosen to make best use of what's available. An engine is just an air pump, when you have made it into a better pump it will be able to make more use of more fuel, at that point you can consider changing the carb.
But in any case, a single SU HIF 44 can flow very nearly as much air and fuel as a Weber in a Mini, and mix the fuel into the air more efficiently. The SU is a better designed instrument, you can get very nearly as much power out of it as out of a Weber but using a lot less fuel.
#9 blister
blister
  • 1,008 posts
Posted 08 July 2006 - 12:17 PM
just wondering if any one has the plans for the parcel shelf, dash, center console, and boot liner..
