So my SPi was running great until it wasn't. after doing a lot of reading and tinkering with the ECU I decided to simplify the whole system and convert to Carb. So I pulled out all of the SPi bits including the ECU and relay module. then i fitted an Aldon Yellow A+ dizzy, a Flame thrower road ignition coil, a heated inlet manifold and HIF44 Carb and a Petral King fuel pressure regulator. everything is plumbed and throttle cable is connected. After several hours looking at the wiring diagrams i wired up 3 relays to the ignition switch (starter/fuel pump/ignition) and all the circuits seem to be function as expected. so then i set the static timing according to the Haynes shop manual. and alas when i turn the key, the engine turns on the starter motor but nothing else. I've checked the spark and I'm getting a nice strong blue arch. and i've checked that there is fuel flowing into, and i haven't messed with any of the settings on the carb because the instructions in the box said that the carb was set up for inital starting.
Also I'm fairly new to minis and this will be my first carbeurated car so please don't assume that i have any prerequsite knowledge. thanks in advance for all the help.
