I'm baffled guys and could use some help...
After installing a new engine (long story), I was hooking up electricals and noticed the brake light switch on the brake pedal in the cabin was broken. Ordered a new one and went to look for the wires but I can't find them (what the hell?).
According to the Haynes diagram, the lead INTO the switch is a switched green lead that goes into the cabin straight from the fuse block, and the electrical current OUT OF the switch is carried to the tail lights by a green/purple wire. Right now NEITHER wire is connected since I can't find either one.
Here's the thing... when I switch on the ignition MY BRAKE LIGHTS ILLUMINATE. According to the diagram, this is impossible, since the only way for current to flow into the green/purple stop light wires is via the brake switch.
I checked the tail lights by switching the ignition off but then turning ON the main headlight switch and as expected the tail lights (not the brake lights) illuminated. Switching on the ignition immediately illuminated the stop lights, like there's a direct connection between the hot, switched green lead and the green/purple (which I can't see how happened).
I tried tracing the wires from the tail/brake lights back forward, but they go up into the LH rear a-pillar (behind the gas tank) and I cannot follow them. It appears as if the green/purple wire reappears on the LH side via the front a-pillar hole and then passes through the firewall right near the wiper motor. Beyond that all the wires are wrapped in tape and can't be seen.
Ideas? I can snip the green/purple wire up front near the a-pillar and then splice in a new lead to the brake light switch (along with a second, green lead to the switched hot), but I hate the thought of having some weird, random (possibly still hot and short-able) connection somewhere inside the harness...
Thanks! --Matt
Edited by ImagoX, 23 November 2014 - 01:17 AM.
