Top Suspension Arms.
7 replies to this topic
#1 Burnard
Burnard
  • 3,350 posts
Posted 23 November 2014 - 10:55 AM
Hello,
I will have my engine out soon so will be changing my top suspension arms at the same time as they need doing  (more for piece of mind when pushing 200bhp :gimme:  )
Does anyone know the difference between a hydrolastic top suspension arm and the more common dry one?
I was sort of hoping that one would be stronger than the other with not much other change. But if someone could tell me all the differences so i can make an informed decision that would be much appreciated.
Also if you have a picture of them next to each other could you please post it so that i can see.
Cheers,
Chris.
#2 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 23 November 2014 - 11:05 AM
I believe the knuckle cup is in a different place, changing the suspension ratio.
#3 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 23 November 2014 - 11:08 AM
+1
#4 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 23 November 2014 - 11:10 AM
If you really feel you need stronger ones you'll have to speak to Fast Carl.
#5 Spider
  • 15,684 posts
Posted 23 November 2014 - 07:31 PM
Later arms 'look' to be stronger than the very early arms. As the other guys have said, the Dry vs Hydro Arms have diffent ratios (look to be the same casing though), fitting Hydro Arms in a Dry Car will make it stiffer (harder).
#6 Burnard
Burnard
  • 3,350 posts
Posted 23 November 2014 - 10:47 PM
Do you know how much stiffer, or what the ratio change is?
#7 nicklouse
  • 18,998 posts
Posted 23 November 2014 - 10:49 PM
Also the bolt hole is different as it does not need to hold a damper on the hydro car IIRC.
#8 Spider
  • 15,684 posts
Posted 23 November 2014 - 11:16 PM
I did measure some Arms a while back to get the correct Ratios;-
     Dry Arms    5.18:1
     Wet Arms   4.82:1
I think somewhere it was published that the Dry Arms were 3.0:1, I'm not sure where that came from and I can't see how that was arrived at.
