My mate has a lightend flywheel. and when he put it in the car it cut the engine out completely. It was all installed corectly (hes done it 40times on the same car and no problems before). Any idea what the problem could be??
wb ASAP please.
Lightend flywheel problems!!
Pie
, Jul 07 2006 05:37 PM
8 replies to this topic
Posted 07 July 2006 - 05:37 PM
Posted 07 July 2006 - 06:42 PM
Well, if you want a quick answer you'll have to give a bit better description of what's wrong and tell us what car it is at least.
Posted 07 July 2006 - 07:26 PM
when u put your foot on the clutch it cuts out.
Its a 76 mini. with a 1275 reborred to a 1330 with webber 40DCOE and a sccr box.
any more info needed?
Posted 07 July 2006 - 08:11 PM
thats needs the two big nuts on the end of the clutch plunger adjusting, as the cluch has over throw, and loading up the thrust washers, or the other problem could be thrust washers
dave
dave
Posted 08 July 2006 - 09:56 AM
Already tried adjuting them. And the thrust washers have been replaced iver and over again. No one seems to know what the problem is. Tim@mini mail, minispares, min-its and huddersfield have no idea what it is! Theyve never come across it before!
Posted 08 July 2006 - 08:35 PM
Have you changed yhe release bearing, It may be seized????
Posted 08 July 2006 - 08:37 PM
its deffo overthrow that causes the problem, how much end float on the crank?
dave
dave
Posted 08 July 2006 - 08:54 PM
Sounds like thrust bearings to me too.
Interestingly my new engine droped around 400rpm when I put thr clutch in when I first started it, but after a while they bedded in and now the rpm satys constant.
The other thing it might be is the flywheel or back plate catching on the flywheel housing. I've seen this happen when the end flat is too big and the flywheel fits on the crank a long way.
Wil
Wil
Posted 08 July 2006 - 09:21 PM
I was thinking a similar thing to you Will. If the clutch really has been on and off this crank 40 times then both the tapers could be quite worn, driving the flywheel further up it. Then it could throw the clutch far enough to hit the casing even if it is properly adjusted.....
Just a thought.
Just a thought.
