Just a quick question would anyone recommend this by maniflow ? Is it anygood for road use cheers http://www.maniflow....61&product=1388
Posted 24 November 2014 - 02:51 PM
Posted 24 November 2014 - 02:58 PM
That is a very nice exhaust system and is ideal if you have a 1275 and intend to do further improvements later, such as improved head & cam.
Highly recommended.
Posted 24 November 2014 - 03:06 PM
Okay thanks sounds ideal for what I want because in the future im hoping to do a head and Cam change :)
Posted 24 November 2014 - 03:32 PM
I put one on my newly-rebuilt 1275 (basic street tune) connected to a LCB exhaust header, and love it - sound is great and the performance is lovely. I did use a slightly richer needle in my twin-SU carbs through due to the fact that my version is straight-through with no cat. --Matt
Edited by ImagoX, 24 November 2014 - 03:33 PM.
Posted 24 November 2014 - 04:00 PM
Oh right I've got a set of Twin Hs2s to go on when I get around to build them up I've just fitted a rebuild kit to them both and currently got GY needles fitted but as I said haven't got around to fitting them to car yet might be after new year before I do and get it on a rolling road. what needles do you have in yours? cheers
Posted 24 November 2014 - 04:13 PM
My SUs are currently running "M" needles. The mixture was almost perfect at the default 12 flats down from flush, and acceleration is snappy with no hesitation or bogging anywhere. I'm planning on having a proper tune done with an oxy sensor in the tailpipe though when the weather gets warm - the carb builder recommended swapping to a slightly leaner "AN" needle if needed, so I just ordered both and have them as back-ups at the moment,
Hope this helps...
Posted 24 November 2014 - 04:14 PM
How quiet do you want it to be?
Posted 24 November 2014 - 04:38 PM
Hope this helps...
Okay thanks seems like a plan and I'm not too bothered about the noise aslong as I doesn't sounds like a bean can on a Subaru
Posted 24 November 2014 - 04:47 PM
The Maniflow I have (center-exit, single port) is actually pretty quiet. Maybe a tad louder than the side-exit stock unit, but not at all annoying, shrill, or growly (at least at idle; I'm inside when I'm accelerating and can't really tell). It's definitely got a bit more of an audible "punch" at the low end, though - I personally really like it. And best of all, it mounted right up - all I needed to do was drill a pair of small holes in the center of the rear sub frame - fitment was PERFECT into the LCB.
Let me know if you need/want any pics. Good luck! -Matt
Posted 24 November 2014 - 04:57 PM
Yeah I prefer the maniflow systems to the RC40s and I know theyre a good quality brand so really looking forward to fitting it. Does it really matter if I fit the exhaust before I fit the carbs or does this have to be done at the same time ? cheers
Posted 24 November 2014 - 06:12 PM
I fitted mine several weeks before I did the carbs - LOTS easier to get the rear manifold nuts situated with the carbs off, I think (it was for me, anyway - with the carbs on, I simply couldn't reach the center nuts AT ALL).
Also, do yourself a favor and get the extra-long brass nuts to secure the exhaust and intake manifolds on the back of the block - they make things so much easier. These are the ones I used:
http://www.7ent.com/...ng-51k1177.html
Posted 24 November 2014 - 06:51 PM
Posted 24 November 2014 - 09:30 PM
