I have a 1999 Rover Cooper Sportpack and a couple of weeks ago I went to start it which it did and ran normal until I switched it off, upon trying to re-start it started and then cut off after approx 3 seconds.
I have checked all sensor connections with no luck, I called for an auto electrician who diagnosed the ECU to be at fault. I sent the ECU away to be re-furbed and it came back with no faults.
I have changed the Relay module and still no luck, it starts and runs from cold but when you switch it off it starts then cuts out after 3 seconds.
I am at my wits end and long for a simple solution to this problem, if any-one has had the same problem could you let me know th solution i would be very grateful.
