Universal Seat Frames
8 replies to this topic
#1 fenghuang
fenghuang
  • 796 posts
Posted 30 November 2014 - 05:44 PM
I've seen various companies selling "universal" seat frames. Some seem to also mention Cobra seats, so I was wondering how "universal" they are. What degree of fabrication is usually involved in fitting non-mini front seats with or without these frames? Does the cross beam ever cause problems?
Edited by fenghuang, 01 December 2014 - 05:46 PM.
#2 Grimshaw17
Grimshaw17
  • 221 posts
Posted 30 November 2014 - 05:46 PM
I found mini tilted back a bit too much, yet to try them with my metro seats but have to modify them to fit anyhow
#3 olosteve
olosteve
  • 158 posts
  • Local Club: N.M.O.C.
Posted 01 December 2014 - 04:09 PM
Quite a bit of work to do to fit, Metro seats. Back seats you have to cut all the base metal work off and cut 6" off each side. Back rest you need to trim the top corners. Front seats need to be raised at the back. Very worth doing as so much more comfortable.
Edited by olosteve, 01 December 2014 - 04:10 PM.
#4 fenghuang
fenghuang
  • 796 posts
Posted 01 December 2014 - 05:49 PM
Are Metro front seats typical in the modifications needed? And are you fitting them with "universal" frames or some other way?
#5 Grimshaw17
Grimshaw17
  • 221 posts
Posted 01 December 2014 - 09:55 PM
Only fitting the front ones as the back seats are never used and got a pair for £10!
I plan on using some universal frames and then producing some brackets to allow the narrower mounting points, hopefully it will work... If not I will solid mount them with the original frames
The universal frames worked ok with some lowback bucket seats, however didn't slide back very far and tilted, personally I believe you are better off buying the frames from the manufacturer as they are produced for the intended seat.
#6 fenghuang
fenghuang
  • 796 posts
Posted 03 December 2014 - 01:54 PM
I (should) have a set of BMW Recaros. I'll be plesantly surprised if there are frames manufactured to put them in a Mini ;-)
#7 Grimshaw17
Grimshaw17
  • 221 posts
Posted 03 December 2014 - 04:30 PM
Oooo nice! Yeah good point, will have to fabricate some then
#8 fenghuang
fenghuang
  • 796 posts
Posted 03 December 2014 - 08:49 PM
Do you think universal frames would be worth while, or is more likely to be a case of starting from scratch? If so, what sort of structure do you think will need fabricating?
(I can't get to see what framework will come with them, so I have no idea what to expect.)
#9 Grimshaw17
Grimshaw17
  • 221 posts
Posted 04 December 2014 - 10:12 AM
From what I have seen people mount them in two ways (someone might be along with other ideas):
Start from scratch, Use the original BMW sliders and weld in a cross member from the tunnel to the sill in the rear foot well, then mount the rear of the slider and either make some brackets for the front to use the existing points or make new mounting points on the cross member. (although i think this compromises space in the back)
or
Use universal subframes, produce some brackets to go from the bmw seat mounting holes to the narrower universal seat frame. Using some flat steel bar. This is what I plan on doing with my metro seats, ive attached a quick paint diagram in how I intend on doing this. The steel bar would have to be thick enough not to flex however.
Heres a useful link aswell:
http://www.theminiforum.co.uk/forums/topic/63013-seats-that-fit-in-the-classic-mini/page-22
Edited by Grimshaw17, 04 December 2014 - 10:14 AM.
