Part Identity
18 replies to this topic
#1 newenglandmini
newenglandmini
  • 646 posts
Posted 30 November 2014 - 09:58 PM
What is this part?  My parts bag label is not readable.
Thanks.
Attached File  DSCN6091.JPG   57.14K   127 downloads
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,839 posts
Posted 30 November 2014 - 11:01 PM
nothing I recognise.... have you any idea which part of the car it came from...
The bolt in the back ground looks decidedly reverse thread, no idea
Edited by Guess-Works.com, 30 November 2014 - 11:02 PM.
#3 newenglandmini
newenglandmini
  • 646 posts
Posted 01 December 2014 - 12:45 PM
The bolt is right-hand threaded.
The parts bag was in my "gearbox/clutch" parts bin, so I believe the parts are so related.
#4 nicklouse
  • 18,999 posts
Posted 01 December 2014 - 01:09 PM
so internet camera with reversed picture?
what year rebuild? I have seen similar but god knows where.
needs to think..
#5 newenglandmini
newenglandmini
  • 646 posts
Posted 01 December 2014 - 08:06 PM
1974 Mini 1000, all original parts.
#6 nicklouse
  • 18,999 posts
Posted 01 December 2014 - 09:33 PM
I am sure I have had one of them spare myself. And IIRC it came with a remote servo.
It just looks so familiar.
#7 GraemeC
GraemeC
  • 7,467 posts
Posted 01 December 2014 - 10:21 PM
How big is it (no way of scaling)?
Any more pics from different angles?
#8 newenglandmini
newenglandmini
  • 646 posts
Posted 02 December 2014 - 01:20 PM
More pics -
Attached File  DSCN6092.JPG   78.94K   22 downloads
Attached File  DSCN6093.JPG   75.16K   12 downloads
Attached File  DSCN6095.JPG   65.01K   9 downloads
#9 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,839 posts
Posted 02 December 2014 - 01:50 PM
I think that's just a bent bit of tin which someone has bodged at some stage, probably use to be a U shape...
The bottom Bolt and Nut however, is for connecting the upper rod of the rod change mechanism to the bush in the back of the gearbox.
#10 newenglandmini
newenglandmini
  • 646 posts
Posted 02 December 2014 - 02:27 PM
I don't think it was bodged.  It is too well formed for that to be the case.  I didn't take photos of that part of the car prior to disassembly, so I can't determine its original location.  Your hint regarding the bolts suggests that the part is from that area.  Barring any further info, I'll look to fit it there when I reassemble.
#11 nicklouse
  • 18,999 posts
Posted 02 December 2014 - 02:35 PM
but why? it will make the bolt too short. as in part number 5.
#12 nicklouse
  • 18,999 posts
Posted 02 December 2014 - 02:37 PM
but this has got me thinking.
is the Box "new"  could it just be a transport part in that area?
#13 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,839 posts
Posted 02 December 2014 - 02:39 PM
I use the term bodged, because I don't believe it was originally designed for the purpose it has been used for...
I suspect that someone has tried to straighten a piece of bracket which could have come of of anything, not necessarily a vehicle let alone a mini, and possibly used it as an exhaust steady, I've seen alsort of things used from meccano, dexion racking, angle iron etc etc etc
#14 Ethel
  • 26,580 posts
Posted 02 December 2014 - 02:40 PM
Remote servo bracket does sound a possibility. It does look like it might be a bit distorted but the curve section looks deliberate, so what would it fit or clear?
#15 newenglandmini
newenglandmini
  • 646 posts
Posted 02 December 2014 - 07:58 PM
What do you mean by remote servo?
