Converting From Alloys To Steels. Another Tyre Question!
Posted 01 December 2014 - 07:32 PM
Question is can I just swap the tyres over or will those not fit the standard steel wheels? Getting confused at looking at posts see something about 5 mm spacers at the rear?
Told originally 145/70 r12 were factory for steels but don't want to spend money on a new set of tyres if I can just swap them as there quite new tyres likewise don't want the tyre failing if not suitable.
Posted 01 December 2014 - 09:58 PM
Posted 02 December 2014 - 11:11 AM
Posted 02 December 2014 - 11:53 AM
I used 165 tyres on my steel wheels. There weren't any clearance problems at the back but my car has the standard spacer type drums.
Posted 02 December 2014 - 05:16 PM
With standard 165/60 x 12 you will not have any problem.
The problem which can occur is that with 165/60 x 12 tyres with a reinforcing bead on the sidewall, as is found with some 'winter tread' pattern tyres, the reinforcing rib can just touch the radius arm and 3 mm or 5 mm spacers are needed to move the inner edge of the tyres out slightly. This only applies to wheels with the standard datum offset.
Posted 03 December 2014 - 09:40 AM
Posted 03 December 2014 - 09:53 AM
One thing I just remembered is that I do have the early 12" steel wheels with the extra plate or thin spacer on them. The later ones don't have this and I never really understood what they were actually fitted for. The extra bit is only about 2mm thick so I thought it was either there to give added strength or to help locate the wheel on the hub better.
These spacer type wheels were around a long while before Dunlop introduced the 165 tyres so can anyone suggest why they were fitted ?
I don't think this will make any difference in terms of fitting the wider tyres on the steels but it got me thinking.
