Discs Behind 10 Inch Steels?
18 replies to this topic
#1 CaraMillar
CaraMillar
  • 174 posts
  • Local Club: No club
Posted 01 December 2014 - 09:08 PM
So I've just bought myself and project and other than tarting up the shell I plan on stripping the subs, painting and replacing parts etc. anyways I plan on the car running on 10inch steels! The question is .... Can you put discs behind a 10 inch steel? If so, where is the best place to get the stuff?
If this is a silly question I'm sorry. This is my first ever build from a shell :-/ the Haynes and lots of posting will be happening haha
#2 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,078 posts
Posted 01 December 2014 - 09:13 PM
What have you got at the moment? You'll need 7.5",7.9" or 7" discs, although 7" ones are surposed to be as goo as drums. 7.5s is most common which you can buy a drum to disc conversion at about £450 or 8.4 to 7.5 disc for about £200, If you don't have 8.4's already I would try and get a set and then get the conversion as it works out alot cheaper.
#3 CaraMillar
CaraMillar
  • 174 posts
Posted 01 December 2014 - 09:14 PM
It's on drums at the mo! With ten inch steels I'm open to whatever will work the safest but I really want the 10 inch steels
Edited by CaraMillar, 01 December 2014 - 09:17 PM.
#4 alex-95
alex-95
  • 6,078 posts
Posted 01 December 2014 - 09:22 PM
I would get this set http://www.minispare...|Back to search and then find a set of 8.4's with drive shafts, it'll work out alot cheaper than buying this kit. http://www.minispare...28.aspx|Back to
#5 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 01 December 2014 - 09:23 PM
7.5s with a remote servo setup on mine on 10s really good.
8.4s you either have to run 12s or machine the discs down
Edited by KernowCooper, 01 December 2014 - 09:24 PM.
#6 CaraMillar
CaraMillar
  • 174 posts
Posted 02 December 2014 - 01:27 PM
#7 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,168 posts
  • Name: Neil
Posted 02 December 2014 - 03:44 PM
Your standard steel wheels will not fit over discs so you will need a set of Cooper S rims.
he is now sitting a lot lower as the cones are settling.
#8 CaraMillar
CaraMillar
  • 174 posts
Posted 02 December 2014 - 04:17 PM
Aw really? :-/ might be drums for me then!
#9 alex-95
alex-95
  • 6,078 posts
Posted 02 December 2014 - 05:02 PM
You sure neil, Pretty sure I've see people running 7.5s with 3.5x10 rims.
#10 mister bridger
mister bridger
  • 912 posts
Posted 02 December 2014 - 05:50 PM
I have 7" cooper discs on my mk1 and they're not as bad as people make out if kept in good nick. I was very dissappointed with a later Mini I had for a while with 8.4" discs that felt no better at all. And standard 10" steel wheels fit over the 7" discs no problem
#11 Cooperman
  • 23,513 posts
Posted 02 December 2014 - 05:56 PM
The standard steel 10" wheels should always fit over the 7.5" 'S' discs and callipers. However, the standard Cooper 'S' 3.5" or 4.5" steels won't fit onto drum braked or 7" disc braked cars.
#12 megamini_jb
megamini_jb
  • 5,491 posts
  • Name: Jamie
Posted 02 December 2014 - 06:01 PM
I've had 3.5 standard steel wheels over 7.5 brake set up before without no issues at all
Edited by megamini_jb, 02 December 2014 - 06:03 PM.
#13 sonikk4
sonikk4
  • 16,168 posts
  • Name: Neil
Posted 02 December 2014 - 06:34 PM
Oops could be wrong then there so apologies. Saying that never tried my old Steeles over the discs. Dohhhhh!!
#14 Cooperman
  • 23,513 posts
Posted 02 December 2014 - 09:52 PM
I believe some standard (non-S) 3.5" wheels do just touch the callipers, but not all of them. In fact I think it was early '60's 3.5" non-S wheels which gave the problem.  They will stick out a bit, but at 3.5" it won't be an issue.
#15 Alex_B
Alex_B
  • 4,573 posts
Posted 02 December 2014 - 11:05 PM
I am running 3.5" steelies that have been cut and banded to be wider. But the inside profile and width of the rim is unchanged and fits under 7.5" brakes
