Ball Joint Spacers
15 replies to this topic
#1 jt19
jt19
  • 745 posts
Posted 02 December 2014 - 05:09 PM
Hi
Was just wondering if these are worth getting if your mini is lowered? I know the miglia use them.
Im on about a spacer that goes on the bottom ball joint in case anyone is confused. I can't find a decent pic of one.
Josh
#2 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 02 December 2014 - 05:27 PM
You mean the ones that screw into the hub?  I think KAD do them
http://s281.photobuc...591c_1.jpg.html
#3 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 02 December 2014 - 05:29 PM
I've never known at what point they become "necessary".  I suppose the theory is that it corrects the roll centre on really low cars?
Gawd knows, but I'd like to understand more about it!
#4 jt19
jt19
  • 745 posts
Posted 02 December 2014 - 05:59 PM
Yes that's them. Think owens fabrication does them aswell.
I'm changing my brakes and hubs to mini ones. And wondered if I should get a pair before I get it all set up.
#5 nicklouse
  • 18,684 posts
Posted 02 December 2014 - 07:28 PM
Necessary and correcting the roll enter as two interesting concepts.
Lowering the mini at the front lowered the roll center. Adding the ball joint spacers will raise the roll center.
What the spacers can do is help with clearance issues. Bottom arms being in contact with the hub when approaching full lock.
For a road car I don't think you will be going anywhere near that far.
#6 Spider
  • 15,091 posts
Posted 02 December 2014 - 07:56 PM
I was just about to make up something just like these, I had no idea anyone was offering them off the shelf.
Just looked at The KAD Website and couldn't see them, could have they come from another supplier?
Thanks for sharing.
#7 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 02 December 2014 - 08:14 PM
Mondosport may do them?
#8 nicklouse
  • 18,684 posts
Posted 02 December 2014 - 08:15 PM
There are a few people making them but I can't think of one of them. Owens have made them. And there is another.
#9 nicklouse
  • 18,684 posts
Posted 02 December 2014 - 08:18 PM
That is who I was thinking of.
https://www.facebook...57986624&type=3
#10 Tupers
Tupers
  • 4,156 posts
Posted 02 December 2014 - 08:33 PM
Owens, KAD and Mondo Sport have all made/make them. There are probably a few other Miglia regulars who have there won version including Selby Engineering who do what probably the best engineered version. There's a very good explanation of how it works on their Facebook page.
I have a set of the Mondo Sport style ones for my estate but it's yet to see the road.
#11 Spider
  • 15,091 posts
Posted 02 December 2014 - 09:24 PM
Many thanks for the leads guys, appriciated :)
#12 nicklouse
  • 18,684 posts
Posted 02 December 2014 - 09:30 PM
Here is an interesting picture for you.
Attached File  image.jpg   54.55K   55 downloads
That is how low you can go before you blow the ball joints.
Bit of wood just slides in. 100mm
Ahh the wonders of iProducts. Sorry upside down.
Edited by nicklouse, 02 December 2014 - 09:31 PM.
#13 jt19
jt19
  • 745 posts
At what point do you think it's worth fitting a pair?
#14 Tupers
Tupers
  • 4,156 posts
Posted 02 December 2014 - 09:50 PM
The Miglia/Se7en set-up guide recommends a ride height of 7.25" from the ground to the sill seam at the bottom of the A-panel and 8.25" from the ground to the sill seam in front of the rear arch. The Miglias are also tubbed and have the wings trimmed out for tyres clearance to allow them to run that low.
I would measure your car then call Mondo Sport or Owens Fabrication and ask them to be honest. It's also worth noting you'll need adjustable bottom arms and tie bars to get the geometry right.
#15 nicklouse
  • 18,684 posts
Posted 02 December 2014 - 09:56 PM
I don't.
But like I said there can be instances where they are needed due to clearance issues.
