Fuel Filter Replacement Found Without The Adapters
4 replies to this topic
#1 cooperminispi
cooperminispi
    Just On Tickover
  • 7 posts
Posted 02 December 2014 - 05:55 PM
I've been trying to find information for a suitable replacement to the fuel filter I no longer have the original filter connections but rubber injection fuel lines.
I popped in halfords today and compared many to their on the shelf Mini Cooper filter, I have managed to find one that will fit the original filter bracket with the connections to put the rubber hose directly to it.
Filter code HFF204
Will have to keep an eye on it but is a perfect fit
#2 minimat
minimat
  • 690 posts
  • Local Club: anglian mini club
Posted 03 December 2014 - 08:24 PM
Any idea what car it should fit so people can use other make filters?
#3 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 03 December 2014 - 08:32 PM
Mk1 mx5 fuel filters have simple pipes for pushing fuel line onto. They are only about a fiver too.
#4 Alpenflitzer
Alpenflitzer
  • 396 posts
  • Local Club: no
Posted 07 December 2014 - 11:23 AM
http://www.ebay.co.u...=item35dc32ec12
this one is only 5.25GBP and a high quality product.
#5 humph
humph
    How bad can it Be?
  • 1,109 posts
Posted 07 December 2014 - 01:00 PM
When I replaced mine the OEM filter had seized so I removed the inlet and outlet pipes and replaced them with flexis and a push fit filter, and if I'm reading your post correct this is what you've done.  The filter I used was a Coopers FIAAM filter reference FT5207, originally for a Vauxhal Astra. Filts well in the existing filter bracket as it's very close to the original dimensions.
http://www.sogefifil...f_filtre=FT5207
