Another Hick Up In The Road....help!
14 replies to this topic
#1 pretzil
pretzil
  • 1,348 posts
  • Local Club: Mary-Q-Crew!
Posted 06 December 2014 - 06:06 PM
Hay all, so after yesterday's mistake of filling the mini to then find out the fuel line and broke and started flooding my boot with petrol!! Which has now rusted the paint work lol we finally have that all done and all wired up but now i have a new problem....... We put the battery in to start her up and......nothing.....no power!! The battery is fine so I don't know what's wronge....please help as I have no idea what to do...when we put the connectors on the battery it didn't even spark like it normally does?! Xx
#2 mingy
mingy
  • 930 posts
Posted 06 December 2014 - 08:59 PM
The battery should not spark if you connect the negative ( - ) cable first and then the positive ( + )  last which, is the correct procedure, a good job you didn,t connect them like that when you had the fuel leak, otherwise November the fifth 2015 would of come early........ :ohno:
#3 pretzil
pretzil
  • 1,348 posts
Posted 06 December 2014 - 09:10 PM
Lol I don't mean a spark as in sizzling showers of sparks I just mean a little tingle spark. But i want to know why there's no power ¦[ iv got the mot booked this week so need to figure it out ¦:'( Xx
#4 robminibcy
robminibcy
  • 1,516 posts
Posted 06 December 2014 - 09:12 PM
are you sure neg first is correct? I ve always been told negative off first and on last. Cant remember the reason behind it but made sense at the time.
what year mini is it? If its an earlier one check the starter solenoid is earthing correctly on the inner wing. Later ones have the solenoid on the starter so make sure all the wires are connected properly
#5 Carlos W
Carlos W
  • 10,114 posts
I thought you were meant to connect the positive first, then the negative meaning if you touch the bodywork when tightening the positive you don't short it.
#6 pretzil
pretzil
  • 1,348 posts
Posted 06 December 2014 - 09:17 PM
Cool yeah mines 1984 city so will check the earth it might be due to the rubbish yellow paint work.someone's done to the engine bay that might be stopping.it from earthing properly x
Edited by yeti21586, 07 December 2014 - 12:00 AM.
DONT BYPASS THE SWEAR FILTER!!
#7 cookie4343
cookie4343
    **Caution: Do Not Feed Alcohol**
  • 2,257 posts
  • Local Club: CV1 Mini's
Posted 06 December 2014 - 09:18 PM
To disconnect its earth first then positive, then to reconnect its positive first then earth.
#8 mingy
mingy
  • 930 posts
Posted 06 December 2014 - 09:34 PM
My apologies for misleading info, got it wrong way round ( brain storm ) or too many whiskies.
Have slapped myself on the wrist for this.....  SORRY.
#9 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 06 December 2014 - 09:45 PM
you have a multimeter?
#10 ScrambledEggs
ScrambledEggs
  • 30 posts
Posted 06 December 2014 - 10:53 PM
A multimeter will help you find the fault a lot quicker but if there's no power at all (assuming the battery is ok) then my first guess would be a fuse. Next check connections, make sure its grounded properly etc.
Edited by ScrambledEggs, 06 December 2014 - 10:54 PM.
#11 pretzil
pretzil
  • 1,348 posts
Posted 06 December 2014 - 11:48 PM
whats a multi meter lol  no i dont have one and dont think jay does either.....yeah theres no power atal, no horn,lights or anything works lol x
#12 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 07 December 2014 - 09:28 AM
https://www.google.c...ved=0CAcQ_AUoAg
thats a multimeter.
Did you have power before you replaced the battery?
#13 pretzil
pretzil
  • 1,348 posts
Posted 07 December 2014 - 02:30 PM
No no power before, but iv now worked it out, the two wires that come from the battery into that thing attached to the wing was the wrong way round lol so now i have power but now found out the fuel pump isnt pumping so were just taking it all apart to fix that now then got to play around with the fuse box lol x
#14 woodley miniman
woodley miniman
  • 304 posts
Posted 07 December 2014 - 09:56 PM
The solenoid, is that what your talking about???
#15 pretzil
pretzil
  • 1,348 posts
Posted 08 December 2014 - 08:51 AM
yeah if thats what its called :P
