Restoration And Shell Information
3 replies to this topic
#1 Jbooker1
Jbooker1
  • 16 posts
Posted 07 December 2014 - 06:03 PM
Hi experienced owners. I'm hopefully going to start my first resto project and along with the car the owner is adding a shell to the package. Here are some questions.
1. From the only pic I have, should this shell have any id or plate identification?
2. Is the shell even needed if I'm only going to replace just a few panels?
3. Any other things I should look out for or be aware of when I go see it?
(The resto will be the yellow pic)
Thanks community.
#2 ScrambledEggs
ScrambledEggs
  • 30 posts
Posted 07 December 2014 - 06:33 PM
Sorry I can't help with your questions but where is the car/shell? I assume not in the UK from the pics.
I would love either and you're getting both!
#3 Almond-1
Almond-1
  • 203 posts
  • Local Club: Cooper Register
Posted 07 December 2014 - 06:56 PM
The yellow shell is left hand drive & as this is the restoration item, best to stick with it. Both are MKI's & should have body numbers on the bonnet shut panel ( if they haven't been changed).
All though the donor shell it R/H drive, the shells are basically the same.
It will probably suffer from the usual corrosion areas ( basically every where). If you intend to restore it correctly, then strip it to a bare shell & get it shot blasted.
This will more than likely show many more areas of corrosion.
But it will pay dividends in the end & don't throw anything away until you another item or it has been refurbished.
In the end it's up to you.
#4 62S
62S
  • 1,244 posts
  • Local Club: You must be joking!
Posted 07 December 2014 - 08:49 PM
If the yellow car really is a Cooper then it would generally be worth more if you keep the original shell - assuming it still has its original shell.
The white shell looks pretty good so you could probably sell that quite easily and recoup some of the cost of the cost.
