I have a problem where I could see steam coming from the front grille when stationary in traffic. Then there was no heat coming through the heater into the cabin.
I assumed that there was a radiator leak somewhere as the coolant level had dropped.
As a quick fix I poured some rad seal into the coolant tank and it seemed to fix the problem.
Now the problem is back, no heat in the cabin, and steam coming from the front grille.
I have replaced the radiator:
I cannot flush the remainder of the coolant though. About a litre came out when I disconnected the bottom radiator hose, and what was in the old radiator, however the coolant tank is still on max and I need to flush all the rad seal out of the system.
I connected a pressure washer to coolant tank, but it just overflows as if there is a blockage.
How can I flush the remainder of the coolant?
