Help With Wheel Size
5 replies to this topic
#1 adam18uk
adam18uk
    Just On Tickover
  • 6 posts
Posted 14 December 2014 - 06:28 PM
Hi,
I own a 1994 Rover Mini Mayfair 1275 Automatic.
I am thinking of changing from the original wheels and upgrading to a set of super light alloys.
Does anyone know what size wheels I will require?
Also will I need to fit spacers?
Any help appreciated!
Thankyou.
#2 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,026 posts
Posted 14 December 2014 - 06:36 PM
depends what you want, 12's or 13's will fit with the 8.4" disc brakes that you should have. No need to fit spacers, depending on the width you may need to change your arches and cut the wings.
#3 adam18uk
adam18uk
    Just On Tickover
  • 6 posts
Posted 14 December 2014 - 06:45 PM
Thankyou for your response.
I'm after a set of 13's.
#4 Cooperman
  • 23,293 posts
Posted 15 December 2014 - 05:35 PM
If you go from 12" to 13" you will probably be disappointed with the ride & feel. 12" are better as the tyre wall depth is greater and helps absorb the bumps. They are also better in the wet.
#5 Curley
Curley
  • 471 posts
  • Local Club: Not MINI friendly
Posted 15 December 2014 - 11:44 PM
As the other said, what do you want? There is no right or wrong answer*. 10" are best 12" is good and 13" is considered by most to ruin the classic handling.
Also consider the rim width. Too wide a wheel (6-7"+) and the steering becomes heavy. 4.5-5" is best and 5.5" is ok. 6 &7+ serves no appreciable advantage for a road car.
IMO if you can't fit 10"over your brakes or you just want larger then 12x5 with a 165/55 is the smart option. You can fit a 165/ on a 5.5" rim (and many do 'because they like the look) but really its to narrow a tyre and ends up looking like this:
#6 nicklouse
  • 18,600 posts
Posted 15 December 2014 - 11:51 PM
You can fit whatever you want. Getting tyres to fit is another issue. How much bodywork you might need to cut away depends on wheels and if lowered.
Attached File  image.jpg   104.7K   3 downloads
Attached File  image.jpg   105.02K   0 downloads
13" with slicks. 9" wide. Not much A panel of wing. Rear tubed.
