wondering if anyone had some pics or info on how to refit the patrol tank in a rover mini 92?
Edited by dolli93, 16 December 2014 - 08:03 PM.
Posted 16 December 2014 - 08:02 PM
Posted 16 December 2014 - 08:23 PM
Pretty easy to do, put it into the boot close enought to be able to connect the pipes and breather, Then you can stick the neck of the fuel tank the the hole, don't forget the rubber grommet on the body work and the bit of foam around the neck. Then you can fit the strap back on and tighten it down.
Posted 16 December 2014 - 08:36 PM
alright thanks.
Posted 16 December 2014 - 09:02 PM
