I Didn't Know Armoured Brake Pipes Even Existed
Posted 16 December 2014 - 09:05 PM
http://www.ebay.co.u...=item3a833d0ef7
Posted 16 December 2014 - 09:09 PM
There are similar to Armoured Dillo,s.
Posted 16 December 2014 - 09:20 PM
that "armour" wouldn't save you from much aha, you want braided hose :)
COMPLETELY MISREAD THAT.
Posted 16 December 2014 - 09:21 PM
You can use braided lines
Edited by cal844, 16 December 2014 - 09:23 PM.
Posted 16 December 2014 - 09:26 PM
The old Metro twin pipe system had a spiral loop covering them from new, just like these ones.
Don't look that armoured to me, looks more like a normal rubber hose that had a chromed spring wrapped round it.
Posted 16 December 2014 - 09:37 PM
IIRC quite a few cars had them as new - some just had raised plastic ridges
was a way of stopping rubbing when close to struts etc
never liked the idea of braided hoses - you can't see the condition of the rubber underneath
Posted 16 December 2014 - 09:41 PM
braided hoses (good-ridge) don't have rubber in them?
Posted 16 December 2014 - 09:55 PM
They are normally Teflon inside the braid which doesn't break down with age in the same way rubber does.
Posted 16 December 2014 - 10:50 PM
We used these on rally cars for gravel/forest rallies to deflect the stones from the flexible brake pipes. The main brake pipes were always run inside to prevent damage.
They are intended for competition cars only.
Posted 16 December 2014 - 11:48 PM
I've always found the term 'Armoured' to be a subjective one. In general it seems to me what they really mean is better protected than is otherwise 'standard'.
Posted 16 December 2014 - 11:59 PM
I do recall seeing a Mk.1 Lotus-Cortina rally car which had pieces of garden hose (that's what it looked like' over the flexible hoses to ward off stone damage. I guess it would have worked.
Since then the Aeroquip hose has become the thing to use for competition as it has so many advantages.
Posted 17 December 2014 - 06:36 AM
Posted 17 December 2014 - 08:59 AM
I miss read that too!!!!!
