Indicator Not Flashing
7 replies to this topic
#1 lee84
lee84
  • 79 posts
  • Local Club: West Mids Mini Owners Club
Posted 17 December 2014 - 06:36 PM
Hi guys, my driverside indicator is constantly on when selecting right turn, I have noticed the bulb has gone under head lamp, can this cause the indicators not to flash? The drivers side flashes fine when hazard lights on? Any feedback would be appreciated
#2 hellom8
hellom8
  • 188 posts
Posted 17 December 2014 - 06:44 PM
I had the exact same thing, had to replace the bulb and the relay.
#3 mattyglover16
mattyglover16
  • 251 posts
Could be the flasher can that's located under the dash I had to change mine but that was because I have no flash what so ever. Could be a number of things as you have one that flashes and one that doesn't. Sorry if this didn't help I'm sure someone will be along later and be able to tell you.
#4 lee84
lee84
  • 79 posts
Posted 17 December 2014 - 06:49 PM
The passenger side works fine and works fine when hazards on. That's what I can't get my head around, noticed that one bulb was out and was hoping down to that?
#5 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 17 December 2014 - 07:09 PM
Yes if the bulbs gone it wont draw enough current to make the flasher unit make an break the circuit, easier to whip a new 21w 1v bulb in before looking at dirty connection and a bad earth
#6 lee84
lee84
  • 79 posts
Posted 17 December 2014 - 07:17 PM
I thought so, I am guessing this is why flashing fine when hazards on as lights on other side drawing the additional current to make flash?
#7 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 17 December 2014 - 07:21 PM
The hazards will flash on 3 bulbs, if its not flashing slip in a new bulb, if its not flashing then check for 12v on the centre pin and then the earth is ok, and the bullet connectors behind the grill
#8 lee84
lee84
  • 79 posts
Posted 17 December 2014 - 07:42 PM
It was working ok this morning, only difference is bulb out since then.......should of worked that one out for myself really! Lol
