As above, what would this be like ? Will be running with a 12g295 head or 12g940 thanks
Anyone Run A 276 Cam In A 998?
Posted 18 December 2014 - 12:51 PM
Posted 18 December 2014 - 02:11 PM
Used to have one
How it goes it's depending on so many things actually..carbs, manifold arrangement, head work etc
Usable revs 1500-7000
Flies from about 4000 rpm
Best diff ratio 3.44
Posted 18 December 2014 - 02:17 PM
I've got one in my 1380 (i know not the same as a 998) but with a decnet head, lightened flywheel and twin carbs it absolutely flew!!!! right up until the exhaust valve stuck open and it all ended with a bang...ha ha.
Decent cam that everyone overlooks....but what it would be like on a 998 i'm not too sure.
If using a 12G940 head on a 998 block, make sure you pocket the block......been there and snapped rocker arms before working out what was going on!!! (I was 17 in my defence!)
Posted 18 December 2014 - 02:42 PM
Depends on the use of the car. Everyday car : no.
Weekend car: yes . Easy as that ;)
Running a BL 544 cam in mine (288°) , getting a weber on it now, but it flies.
Posted 18 December 2014 - 03:30 PM
Set up right in my 1330 it is drivable every day, but I would imagine its not so much torque in the small block engine
Posted 06 January 2015 - 11:52 AM
thanks, think I will look for 266
Posted 06 January 2015 - 01:34 PM
Try Moss-Europe
Posted 06 January 2015 - 06:10 PM
ive just brought a 276 cam for my 998, 12g295 head with 33x29 valves, flat tops ectect, it will be sort of a weekend fun car as I will be able to walk to work, but as said above a friend put a 286 in his 998, it was bloody awful! so I imagine 276 would be just about right for faster driving, for everyday use 266 might be a good move!
