Etch Primer Or Zinc Primer?
2 replies to this topic
#1 woodley miniman
woodley miniman
  • 304 posts
Posted 20 December 2014 - 09:05 PM
Hi all, for bodywork repairs and general use which is the best primer to use? Etch primer or zinc???
Thanks in advance
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,074 posts
  • Name: Neil
Posted 20 December 2014 - 09:06 PM
Welded joints Zinc rich primer, bare metal etch primer, you can then flash over zinc primer if you want to afterwards.
#3 Sawyer
Sawyer
  • 80 posts
Posted 20 December 2014 - 10:33 PM
I use epoxy primer, it has anti corrosion properties and doesn't absorb moisture from the atmosphere like some other primers. So there's no need to worry if you cant work on your car for a period of time. Cleaned bare metal, panel wipe, epoxy, anything after can be done at your leisure.
Apparently you can apply filler directly over epoxy too but a friend of mine owns a body shop and frowns at this, he has always applied filler to bare metal but he is old school =]
