Wheel Arch Fixing Screws - Any Options That Don't Rust?
12 replies to this topic
#1 Genji
Genji
  • 29 posts
Posted 22 December 2014 - 03:27 PM
I've put a new set of wheel arches on the Mini but the screws supplied are not very good quality. They are just blacked (is the finish called "Japaned"?) mild steel and so after about a week they started to rust - they don't look good. Now I appreciate that the kit Mini Spares sells is produced to a price and I'm grateful for that but the screws aren't good enough for me and I'd like to find some better ones. I tried some stainless ones but they just look wrong, I guess I could use rivets but I keep thinking there has to be some black screws that don't rust available somewhere!
What have other people used? These are just the standard plastic arches - correct for the car (1990 Japanese Spec SPI)
#2 rally1380
rally1380
  • 1,893 posts
Posted 22 December 2014 - 03:41 PM
Why not just spray up some stainless steel ones black. That way they won't rust and if they chip, you can just touch them up.  Just tap them gently into a block of softwood to hold them upright and a quick spray with a rattle can and away you go.
Failing that i'm sure someone out there does powder coated ones.
#3 Wise Old Elf
Wise Old Elf
  • 1,655 posts
  • Local Club: Club Lotus
Posted 22 December 2014 - 05:04 PM
Have you thought about pop-rivets?
$(KGrHqN,!hUE49(f2ZsWBOTTY5351w~~48_12.J
http://www.ebay.co.u...=STRK:MEBIDX:IT
#4 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 22 December 2014 - 05:09 PM
Whatever screws you use there will always be corrosion issues, as the screw will expose bare metal behind the panel as the thread screws and bites into the body work. I always use pop rivets as it avoids all these issues and was what was used to hold most arches on in the factory. If you must use screws, then at least dip the thread of each in Waxoyl, or similar first, so that any exposed metal that's created then gets some form of anti corrosion protection. Alternatively Riv Nuts seem to be a popular method used here.
#5 MikeRotherham
MikeRotherham
  • 987 posts
Posted 22 December 2014 - 05:14 PM
Have a look at this:
http://www.titgemeye...ind-rivets.html
I've managed to fasten my back wheel arches on but only able to use 2 each side because the other holes were enlarged.
I've not had time to get some larger ones to experiment.
They do look good though and they are reusable.
If you do decide to get some I'd be interested how you get on.
Regards
Mike,
Edited by MikeRotherham, 22 December 2014 - 05:17 PM.
#6 leaky
leaky
  • 6,890 posts
Posted 22 December 2014 - 06:42 PM
You can buy anodised bolts. Or just fit stainless ones and onces you have screwed them in go over the screws with black nail polish.
#7 Daz1968
Daz1968
  • 2,058 posts
Posted 24 December 2014 - 09:48 AM
I go as above, small stainless bolts with nuts and foam or rubber washer on back to prevent water ingress, just make hole in body big enough so it isn't chipped when pushing bolts through, you can get stainless pozi pan head in black finish
#8 Wise Old Elf
Wise Old Elf
  • 1,655 posts
Posted 24 December 2014 - 10:26 AM
http://www.westfield...t_SHBtn_M4.html
I am thinking of using these M4 stainless bolts.
#9 Steve220
Steve220
  • 5,067 posts
  • Local Club: BMC
Posted 24 December 2014 - 10:44 AM
Stainless steel bolts will be the best option. Some great stainless steel fastener suppliers on eBay.
#10 GraemeC
GraemeC
  • 7,440 posts
Posted 24 December 2014 - 11:54 AM
They're what I use Wise Old Elf - perfect for the job.
#11 Wise Old Elf
Wise Old Elf
  • 1,655 posts
Posted 24 December 2014 - 02:22 PM
Yeah I have fitted others with pop rivets but there is always a risk of cracking the new arch.
I will use the button head bolts this time.
#12 Cooperman
  • 23,326 posts
Posted 24 December 2014 - 07:47 PM
I use M4 Riv-Nuts in the wings and stainless steel socket head cap screws with stainless steel washers (bought from Namrick) to ensure there is no corrosion. Before fitting, coat the riv-nuts with Waxoyl on both sides.
#13 Genji
Genji
  • 29 posts
Posted 16 January 2015 - 04:09 PM
Thanks for the suggestions guys, I wasn't able to find any commercially coloured screws so I painted some stainless ones. I haven't installed them yet but will do when the car comes back from The Real Mini Company - it's having a little rusty bottom fix (the only rust I could find, under the tank and along the rear valance seam)
