E Coat On New Panels
9 replies to this topic
#1 MINIMADrt
MINIMADrt
  • 465 posts
  • Local Club: none at mo
Posted 22 December 2014 - 09:07 PM
evening all
i have read in a few places that you should remove all coatings (E Coat) from new panels does any one no why this is suggested
cheers
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,089 posts
  • Name: Neil
Posted 22 December 2014 - 09:10 PM
Any pattern panel ie magnum needs to have the primer coat removed as its very very poor. Remove it fully.
Heritage is far superior. If it can be easily removed with thinners then its no good.
#3 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
If the ecoat is of good quality scotch it off then prime. If its flakey remove it all. Good ecoat like on heritage panels is a great etch base and rust protection
#4 myredmini
myredmini
  • 3,211 posts
  • Name: Dan
Snap with Neils advice too!
#5 MINIMADrt
MINIMADrt
  • 465 posts
Posted 22 December 2014 - 09:17 PM
ok cheers that makes sense with the 2 different finishes just thought it was strange doing it on heritage as its a really good base..
cheers all
#6 sonikk4
sonikk4
  • 16,089 posts
  • Name: Neil
Posted 22 December 2014 - 09:37 PM
You still need to check the Heritage coating though. Have a good close up look. I have seen spider trails of rust in a couple of panels. This needs to be removed and treated before painting.
#7 minivanman1961
minivanman1961
  • 110 posts
Posted 23 December 2014 - 09:24 AM
I agree with sonikk4. Where we use Heritage panels we always sand them down back to the bare metal for that very reason. You will also inevitably burn some of the coating off anyway when welding the panels up. Where we use M-Machine panels we source them in bare metal. We then use a good zinc based etch primer which we apply once all the dressing of the welding has been done and before we apply seam sealants.
If you are going to use pattern panels and you do strip them to bare metal then make sure you apply your primer soon afterwards as I have seen these panels turn brown within hours of having the e-coat removed.
#8 MINIMADrt
MINIMADrt
  • 465 posts
Posted 23 December 2014 - 09:35 AM
Ok thank you very much for all the advice.
Taken on board and will apply them
#9 Rog46
Rog46
  • 465 posts
  • Local Club: NSMOC
Posted 23 December 2014 - 08:21 PM
+ one
#10 Stu.
Stu.
  • 912 posts
Posted 04 January 2015 - 09:20 AM
I agree with sonikk4. Where we use Heritage panels we always sand them down back to the bare metal for that very reason. You will also inevitably burn some of the coating off anyway when welWe then use a good zinc based etch primer which we apply once all the dressing of the welding has been done and before we apply seam sealants.
I didn't think you could get zinc based etch primer ??
