Hi Guys, just a quick query regarding electrics / ignition match up. I am putting a 1275GT engine (not sure what year engine is ) into my 88 Mayfair. Do I have any problems re. compatibility with type of ignition system ? Did the two have the same set up, I think the mayfair had a ballast resistor ,same with the 1275 ? If not ,what kind of mods do I have to make. Electrics aren't my thing ! Thank-you ,Ferg
Transplant Electrics
Ferg 88
, Dec 27 2014 04:09 PM
2 replies to this topic
Posted 27 December 2014 - 04:09 PM
Posted 28 December 2014 - 09:26 PM
No issues you can run the ballast ignition system in the car unless you choose to use the O.E Lucas 65D4M electric distributor, in which case it just means running a new 12v ignition feed from the White wire on fuse 1and using a 12v coil.
Posted 29 December 2014 - 02:51 PM
Thanks very much for the info . Ferg
