1750cc 5-speed mini
15 replies to this topic
#1 jimbo_edmondo
jimbo_edmondo
  • 1,198 posts
Posted 10 July 2006 - 04:10 PM
Look at this....
Interesting!!!!!
Anybody care to shed any light on it? Will this really fit in a mini? Any ideas on how much modification it'll take? It mentions its on a single bolt subframe, whats that!
It just looks like it could need a bit of radiator relocation?
#2 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 10 July 2006 - 04:13 PM
its a mini maxi engine. and i have never seen one put in a mini as yet, but i may be wrong.
Single bolt subframe is the type. If you look in your engine bay, at the bulkhead in either corner - you will have 1 single HUGE bolt or 2 smaller ones.
#3 Pooky
Pooky
  • 5,691 posts
That should be 50 Cent's car, he calls himself a hustler lol
Thats pretty cool!
I think most later front subframes were single bolt (ie one big bolt at the top of each tower :proud:)
#4 syholl
syholl
  • 710 posts
Posted 10 July 2006 - 04:14 PM
Is that the old Austin allegro engine.... Sounds like it might be. The single bolt subframe refers to most Mini subframes, that have one single tower bolt each side...
#5 TOMMO0302
TOMMO0302
  • 1,688 posts
Hmm, i was going to post 'what the hell does it mean by "the rest of the car is made out of wood!"' but then i scrolled down the page and saw it really is a wooden car.
That engine bay looks huge compared to a standard mini even though he has it on a mini subframe....no idea about the single bolt subframe??!
#6 jimbo_edmondo
jimbo_edmondo
  • 1,198 posts
Posted 10 July 2006 - 04:16 PM
But has anyone seen one in a mini? yea it looks like it could be a squeeze but would be pretty cool tho.
#7 TOMMO0302
TOMMO0302
  • 1,688 posts
Posted 10 July 2006 - 04:17 PM
Very Cool!
#8 16vmini
16vmini
  • 371 posts
  • Local Club: 16v mini club
Posted 10 July 2006 - 04:20 PM
was one in the mini world years ago .. yellow mini , with two big stripes over it .. if i remember ...
i guess its a cheap way to get 5 speeds .... but why only do half a job .. go all the way and use a modern engine.
Matt
#9 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 10 July 2006 - 04:40 PM
it was a go faster thing from the 70's-80's
from what i can remember its fairly stright foward conversion but the engine is a lot heavier :'(
one of the old boy (guessworks) might remember more :proud:
#10 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 10 July 2006 - 05:00 PM
Yes it was also used in the Allegro and in the Princess as a 6 pot version but mainly it's known as 'The Maxi Engine'. It's a good engine but not a great engine.
It IS a fairly modern engine, it's pretty much the last development before the Montego engine in Rover terms and development of the two overlapped. And while it fits into the (auto) subframe pretty well it's tight to get it into the actual car along with a rad. It was a fairly popular mod in the 80's when scrap Maxis were falling out of the sky all over the country.
Single bolt subframes are Mk4 onwards.
#11 Geehawk
Geehawk
  • 500 posts
Posted 10 July 2006 - 05:03 PM
Big heavy gutless lump of iron.
Granted due to its cc it would make a Mini quicker, but so would driving it off a cliff.
Would make your Mini different, but never cool.
Not exactly a popular conversion, even back in the day, but there were not so many decent FWD engine and boxes to choose from then.
#12 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 10 July 2006 - 05:16 PM
I snapped up a 1450cc one for 20 notes. Its a classic, there are not many around
Its one of the easier transplants, but by no means fancy. The only real benefit is the unstressed five speed gearbox with VERY simmilar gearbox output shafts and location.
The 1750 put out around 75bhp, the 1450 was not much different but Austin fitted a restrictor to reduce its out put so that the 1750 would look more atractive ( why would you buy a 1750 when the 1450 almost matched in output?)
They realy aren't that much heavier as some suggest, the bulk is just in a different place, making it a longer taller but rather skinny engine
For the hassle, it would be easier to fit a turbo to the A series and achieve 93bhp straight away as standard
Edited by Mini Sprocket, 10 July 2006 - 05:17 PM.
#13 TWICEmonkey
TWICEmonkey
  • 1,150 posts
  • Local Club: A-Serious.com & TMF
Posted 10 July 2006 - 06:01 PM
That's old skool tuning. That's what the old boys used to do years ago...it's an old trick.
Maxi engines were plonked into Minis oh so commonly in the tuning scene back then. My dad's mate did it and a couple of his mate's too. Apparently quite easy, bit funking deadly, though. They have too much torque causing really bad, and dangerous, torque steer.
This is why it's not done so much anymore, though there was one in Miniworld and MiniMag a few months ago in a gotchic stylee. It was photographed at a show (IMM I think).
The only thng was that at 1st I was confused as to whether he was selling the engine and subframe setup or the whole car. So I sent him an e-mail (you can see it on the bottom of the listing) and asked and he said it was for the whole car, but I can make an offer for the engine if I want it, which is a bit out of order considering people are bidding on the car.
Edited by TWICEmonkey, 10 July 2006 - 06:17 PM.
#14 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 10 July 2006 - 06:49 PM
Yeah but look at the pictures, it's not so much a car as a shipping crate for the engine.
#15 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 10 July 2006 - 07:02 PM
I've seen one, but would never go there myself... you think parts for the A series are hard to get hold off.... weight (punn intended) until you have to replace sommit on that...
Not worth the effort I'm afraid..
