Shall I Fit And If So How Oil Temp Gauge
Posted 28 December 2014 - 12:15 AM
Posted 28 December 2014 - 12:39 AM
Given the above I'd say yes.
You may find you don't need the oil cooler. Do you know where you're going to fit the temp sender?
Posted 28 December 2014 - 08:05 AM
Posted 28 December 2014 - 08:56 AM
Posted 28 December 2014 - 09:13 AM
Posted 28 December 2014 - 03:47 PM
The choice of whether to fit the temperature gauge is largely one of personal preference. In my case, I installed one years ago on a non-Mini and found it to be a waste of money as it did not provide much useful information. However, to each his own.
There are at least four ways I have heard of people adding oil temperature gauges to A-series engines. I have no information on which is best but I'll put them all out there for you to consider.
Make/modify the diamond plate on the back of the gearbox to accept a temperature gauge sending unit. Don't block the oil flow path excessively.
Buy or make/modify a new sump drain plug to accept a temperature sending unit. (You will be sacrificing the magnetic drain plug).
Buy the filter head sandwich plate that allows mounting the sending. (You have to look at the space required around the filter head and subframe).
Buy an inline sending unit housing/fitting and install it in a hose between the filter head and block to support (This replaces the factory pipe).
As for the oil cooler, that again is up to you and how you will use the car. I wouldn't think you needed the cooler in the U.K with today's motor oils. You want the oil to get hot enough to boil off any water/condensation in the engine.
Posted 28 December 2014 - 04:25 PM
if you're still planning on running the cooler without a stat i doubt you'll see a temp gauge move much anyway
Posted 28 December 2014 - 04:48 PM
Posted 28 December 2014 - 05:09 PM
And again I was advised not to run a stat with my engine. What it's going to be used for
Posted 28 December 2014 - 05:54 PM
Posted 28 December 2014 - 10:00 PM
Flywheel end. Make sure you insulate the wires from the heat of the exhaust.
Posted 28 December 2014 - 10:17 PM
You mention no stat. Oil or water? If water I hope the said fit a sleeve instead of the stat.
If oil stat. I would fit the temp guage into that.
But I would not bother with one myself.
