Painting Aluminium Bell Housing
19 replies to this topic
#1 sprite72
sprite72
  • 113 posts
Posted 28 December 2014 - 08:51 AM
Hi all I am unsure what to do at the moment what to do.
One idea was to paint the aluminium parts on the engine .what would be the best process to do on the aluminium parts or paint to do them in .
I was thinking of a silver or white .
#2 Steve220
Steve220
  • 5,115 posts
  • Local Club: BMC
Posted 28 December 2014 - 08:53 AM
White will annoy you after a month as it goes dull or cream. If you do decide to paint it, use course wire wool on the part if it's bare metal.
Edited by Steve220, 28 December 2014 - 10:47 AM.
#3 cubby1701
cubby1701
  • 187 posts
  • Local Club: causeway coast mini club
Posted 28 December 2014 - 09:20 AM
White will annoy you after a month as it goes dull or cream. If you do decide to paint it, use course wife wool on the part if it's bare metal. and where can i buy course wife wool lol. Sorry couldnt resist
#4 59 Speed
59 Speed
    Formally know as Smackfiend
  • 674 posts
Posted 28 December 2014 - 09:26 AM
I cleaned my transfer gear housing and clutch cover with a wire brush in my die grinder or drill, then degreased it with panel wipe and etch primed it:
Attached File  image.jpg   45.07K   7 downloads
After that I gave it two coats of aluminium paint:
Attached File  image.jpg   41.57K   14 downloads
Attached File  image.jpg   45.08K   11 downloads
Hope this helps
#5 Steve220
Steve220
  • 5,115 posts
  • Local Club: BMC
Posted 28 December 2014 - 09:36 AM
Any pics of it fitted?
#6 Steve220
Steve220
  • 5,115 posts
  • Local Club: BMC
Posted 28 December 2014 - 09:37 AM
#7 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 28 December 2014 - 09:42 AM
What is the brand of that aluminium paint?
Looks pretty good in the pics
#8 Spider
  • 15,684 posts
Posted 28 December 2014 - 09:45 AM
Smackfiend, they come up really nice, much respect for the work that went in to that.
While I've not done and and usually, I'm not a fan of it, I have been reliably told that Powder Coating of alloy parts gives very good results,much better than on steel.
#9 59 Speed
59 Speed
  • 674 posts
Posted 28 December 2014 - 09:51 AM
Attached File  image.jpg   113.91K   26 downloads
Attached File  image.jpg   116.2K   17 downloads
Hycote Aluminium Coat - it's cheap!!!!!!
http://www.amazon.co...t/dp/B000LD8T7C
#10 Covert
Covert
  • 526 posts
Posted 28 December 2014 - 10:23 AM
My plan is to get mine aquablasted for that as new look.
#11 Steve220
Steve220
  • 5,115 posts
  • Local Club: BMC
Posted 28 December 2014 - 10:47 AM
I hate the predictive text on apple devices :(
#12 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,168 posts
  • Name: Neil
Posted 28 December 2014 - 11:02 AM
If you are going down this route then I would recommend using deoxidene 624 once everything has been cleaned etc. this will remove any oil and treated oxidisation. We would then normally use Alocrom 1200 to treat the Ali afterwards then etch prime, prime and paint.
Due to how nasty Alocrom is don't bother with that plus it won't be cheap. This is the process we use on Civil Aircraft skin and structure.
#13 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 28 December 2014 - 11:29 AM
Prep is very important when it comes to painting these items.
I did a very through prep or my remote selector box and the housing of my distributor before painting them.
Unfortunately the box they were stored in after being painted got full of water last year and by the time i got them out to dry them off, the paint had wrinkled and started flaking off.
I'm pleased it happened in storage rather than after them being fitted to the car.
I do quite like the colour of that ali paint, but i think perfect prep and the right primer would be key to a lasting finish
#14 sprite72
sprite72
  • 113 posts
Posted 28 December 2014 - 11:47 AM
Wow
Thanks for the reply on this .I will go for the aluminium spray option instead of the paint option I think .
As I only want to do it once .
Thanks all .
Everyone is so helpful on here I am glad I found this site
#15 Craig89
Craig89
  • 600 posts
Posted 28 December 2014 - 11:59 AM
Smackfiend that's a nice looking engine, I do love a white block, will be very high maintenance though.
On the subject of aluminum parts I have just had my clutch and flywheel housings media blasted and don't intend to paint them
Edited by Craig89, 28 December 2014 - 05:32 PM.
