Main Power Cable Alternative
3 replies to this topic
#1 frobnitzz
frobnitzz
  • Just Joined
  • 100 posts
Posted 28 December 2014 - 07:16 PM
Hi,
I need a main power cable for my GT, the one that runs the length of the car. I've got a suitable length of 20mm spl amp power cable, same diameter as a oem cable but lots of strands rather than less thicker ones. Would this be ok to use?
Attached File  rps20141228_191321.jpg   23.54K   13 downloads
Thanks,
John
#2 Spider
  • 15,684 posts
Posted 28 December 2014 - 07:27 PM
The finer stranded cables are actually better, more flexible and a higher rating.
#3 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 28 December 2014 - 07:29 PM
I'd check with the manufacturer the outer sheath is suitable for being out in the underside of the car
#4 frobnitzz
frobnitzz
  • Just Joined
  • 100 posts
Posted 29 December 2014 - 05:04 AM
Ah ok, so in terms of electrical capability all good, but may not be tough enough for the conditions under the car.
I doubt I'll get an answer from the cable manufacturer so I'll either just go with it or route it inside the car.
Much appreciated :)
