SPI Starting problems.
Posted 10 July 2006 - 05:12 PM
Today i took a trip into town, only five miles away. Everything was fine and dandy. I finnished what ever i was doing and came back to my car. I turned the key and she started as normal, but only ran for about half a second and stalled.
Opening the bonnet I found that the relay modual had broken free of its mount and decided to throw itself onto the exahust manifold. Thus melting the case and scorching a relay coil.
Rang the AA man and he found the nearest rover parts dealer for a new relay modual. £33.15 later and we were back at my car. Plugged in the new realy modual, turned the key to II and a relay inside the modual started clicking, like it wasnt latching on. Decided to try and start it anyway, but no joy.
Then the AA man did his standard ignition invest and found out that there was no switch to the coil. We also found out that removing the smaller connector stop the clicking relay. And if we disconnected the fuel cut-off switch the relay stopped clicking, at the same time the stepper motor was doing its thing.
We did a couple of voltage check and found that the white/pink wire in the smaller connector while cranking, which was fine, and the black/pink wire was live with the key at II. We couldnt check anything at the ECU because we didnt know which pin was which.
A couple of more things. I have the standard alarm/immobiliser and an after market TC1 fitted, and yes they were off the whole time. I do know the after market one cuts off the supply to the fuel pump. I also tried re-seting the ECU but it didnt work.
Like i said i have an idea what it is, but id like your comments first.
Bounce
Posted 10 July 2006 - 05:37 PM
Oh and maybe press the fuel cutoff switch just to make sure, and check your fuses.
Although im sure the AA man has done that already
Posted 10 July 2006 - 05:45 PM
Posted 10 July 2006 - 05:46 PM
If its not wiring then my money is on a new ECU :'(
Miniboo, Nancy is still dead in the water
Edited by Bounce, 10 July 2006 - 05:48 PM.
Posted 10 July 2006 - 05:53 PM
Posted 10 July 2006 - 05:56 PM
Posted 10 July 2006 - 06:45 PM
Posted 10 July 2006 - 07:04 PM
Cheers dan
Will i be able to exhange it with no hassle?
Posted 10 July 2006 - 07:09 PM
It might not be the salvation you're looking for but it's a good start.
Yes you can exchange it since they gave you the wrong one.
Posted 10 July 2006 - 07:28 PM
Guess theres still a chance of my ECU being FUBAR due to the fact the wrong relay pack was fitted. I just hope im wrong!
Hopefully she'll be fixed for Dragwars
Posted 11 July 2006 - 09:01 AM
So I have to shell out an extra £46 purely because i drive a mini! I am not a happy bunny!
Posted 11 July 2006 - 09:03 AM
tis a rip off though
Posted 11 July 2006 - 09:06 AM
Edited by Bounce, 11 July 2006 - 09:07 AM.
Posted 11 July 2006 - 09:14 AM
maybe someone on hee has one second hand?
Edited by miniboo, 11 July 2006 - 09:14 AM.
