Hi peeps!
Last week I let someone fettle with my ignition timing, to make this a short story :
his timing light was badly connected in some way or another and he has put the timing at around -6 degrees of advance ( so basically retarded ignition)
Causing a red hot exhaust manifold...
WOudl this blow a headgasket? Only asking as I cant test the car atm ( bad fuelign on my weber,has a bad gasket wich needs replacing).
Car did not overheat ( was 88° coolant temperature)
