Custom Works Exhaust, Center Box Diameter
engine
3 replies to this topic
#1 TehMarchant
TehMarchant
  • 628 posts
Posted 03 January 2015 - 02:38 AM
1275 engine, running a nikki twin choke carb
I am rebuilding my mini as a rally rep.
I really want a works center exhaust and was thinking about custom building one. I want it to be throaty so was thinking of using a cherry bomb center box and a cherry bomb back box. I would then modify it to have a 1.75 diameter center up swept pipe.
Link to the center boxxes I would be using.
http://www.ebay.co.u...=item3a98500e23
Would the performance be effected if I use a 1.75"dia link pipe but  2"dia center box connections then returning to a 1.75"dia tail pipe?
Cheers guys.
Edited by TehMarchant, 03 January 2015 - 02:42 AM.
#2 MrBounce
MrBounce
  • 2,661 posts
Posted 03 January 2015 - 12:29 PM
I would just get the centre part of the RC40 pipe (not that expensive and put a generic centre exit box on the back. This is pretty much what I had with my 1330 GT. It was throaty as anything but could get annoying. I managed to set a car alarm off with it... O_O
#3 TehMarchant
TehMarchant
  • 628 posts
Posted 03 January 2015 - 02:10 PM
I have currently got a rc40 center exit but it is a large bore. was thinking of getting a side exit rc40 and cutting the tip off the backbox and re welding it as a center exit upswept.
#4 Cooperman
  • 23,327 posts
Posted 03 January 2015 - 07:07 PM
Rally cars always had centre exit exhausts to reduce the propensity for the transverse rear box on side exhausts to get damaged on rough roads.
Twin cherry-bombs would be much noisier than a rally exhaust which has to pass strict noise checks.
You can buy an exact replica of the BMC 'works' exhaust systems, although a popular alternative is a twin-box Maniflow system with 1.75" pipes.
