Can You Sit On A Classic Mini Boot?
14 replies to this topic
#1 webby0121
webby0121
  • 117 posts
Posted 03 January 2015 - 12:14 PM
As above, and if not is there anyway to strengthen it to make it possible?
#2 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,033 posts
Posted 03 January 2015 - 12:19 PM
You probably could but I wouldn't advise it, I think the hinge panel would bend a bit, you'd need to add better wires that hold the boot lid up to, and I don't think it goes down far enough to be a good seat.
#3 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 03 January 2015 - 12:25 PM
I wouldn't do it, as said above the hinge panel isn't that strong and the cables aren't made for that either (although more likely to pull out than snap). I am sure you could strengthen it up but why bother? Just stick a couple of camping chairs in the boot.
#4 minikidx14
minikidx14
  • 1,387 posts
  • Name: Ross
Posted 03 January 2015 - 12:27 PM
if you want somewhere to sit outside, unbolt your seats.
#5 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 03 January 2015 - 03:17 PM
You can sit on the boot if you weigh no more than about 20 pounds.
As others have said, don't do it, it will just end badly.
#6 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,058 posts
  • Name: Neil
Posted 03 January 2015 - 03:32 PM
The hinges will more than likely crack as well. So basically the answer is no. As to doing something to strengthen then yes you could do something. You would need to have thicker support cable to start with, then behind the hinge mounts some form or reinforcing bracketry to spread the load into the boot floor with corresponding plates under that as well. As to the hinges well that is a separate issue and would need a design change to increase the hinge strength.
Ohh and just to say i fitted two new hinges to my lads Project Erm and without the support cables both cracked at the pin section.
#7 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 04 January 2015 - 01:59 AM
If you was to go through all of the things needed to strengthen the hinges and hinge panel then you could replace the cables with suitable lengths of chain.
I would say just leave it though. I can't see it being very comfortable anyway
#8 Fast Ivan
Fast Ivan
  • 2,910 posts
Posted 04 January 2015 - 09:26 AM
can you sit on a mini boot lid?
do you really need to ask?
#9 sonikk4
sonikk4
  • 16,058 posts
  • Name: Neil
Posted 04 January 2015 - 12:40 PM
He asked a question as whether it can be done and what needs to be done to try and make it happen. Legit question to be honest.
#10 minimanclive
minimanclive
  • 1,108 posts
  • Local Club: LSMOC
Posted 04 January 2015 - 08:41 PM
If you want to sit in the boot then you need a mini van or estate. No problems sitting in the back there :-)
#11 Chance
Chance
  • 1,457 posts
Posted 04 January 2015 - 08:44 PM
I think it would be pretty good if the work was done to strengthen it..
Range Rover style haha
Was there a weight limit for the luggage you could put on the mk1 folding numberplate ones?
#12 Bubblebobble
Bubblebobble
  • 661 posts
Posted 04 January 2015 - 08:49 PM
Basically you are  going to need a  massive amount of work , either days of work yourself or hundreds of pounds to a confused bodyshop .
 So you can sit on your boot .
#13 Carlos W
Carlos W
  • 10,114 posts
Posted 04 January 2015 - 08:52 PM
A rug in the boot then sit on the ground
#14 MaxAndPaddy
MaxAndPaddy
    Spamela Anderson
  • 4,700 posts
  • Name: Elvis
Posted 04 January 2015 - 10:09 PM
You would be wanting the Minki Mk1
I know I do!  :D
#15 Daviewonder
Daviewonder
    Needs an extra inch!!
  • 1,020 posts
Posted 04 January 2015 - 10:56 PM
I tried it once and the ends pulled out of the cables.
