Which Distributor Please?
7 replies to this topic
#1 Supersouthward87
Supersouthward87
  • 33 posts
Posted 08 January 2015 - 04:46 PM
Could someone tell me which distributor I need please? I had a look on here and through my Haynes and I'm not sure.
It's a 1275 silver seal engine. The old distributor is duff (checked thanks to DKLawson) and I'm not sure the one on it was even right (it's one of the accuspark type electrical jobbies)
Non-ballasted ignition.
Any help appreciated, if you need to know anything else I can probably find it.
Jack  :D
#2 Ethel
  • 26,029 posts
Posted 08 January 2015 - 05:06 PM
DK knows his stuff, but dizzy's only really  suffer terminally from worn shaft bearings.
The main issue is whether the engine is A or A+ - look at how the dizzy is clamped to the block. The alternator bracket is another clue.
Is there an ID number on a metal tag attached to the old dizzy?
#3 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 08 January 2015 - 07:55 PM
What engine was the engine for 1275 wise ?1275 GT Austin 1300 ?
#4 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 08 January 2015 - 08:25 PM
To get a dizzy with the correct advance curve is a bit of a lottery, you can buy an off the shelf dizzy which will be close or there are now mappable electronic distributors available...
One is made by 123 and is available from mainstream mini suppliers ( eg minispares ) http://www.minispare...C-27H7775.aspx, but at £300+vat is a little pricey for me...
I've recently bought an Accuspark Stealth for a customer engine, which is not only programmable, but also uses a stock dizzy body so looks original..
http://www.accuspark...uk/Blackbox.htm
and even purchasing a new dizzy and the stealth unit is half the price of the 123
10408581_788146674555942_723645021097619
Edited by Guess-Works.com, 08 January 2015 - 08:27 PM.
#5 Spider
  • 15,044 posts
Posted 09 January 2015 - 04:29 AM
The Programable Dissys are good, however if you were to consider one of those, as Gues Works has suggested, have a look at the CSI's, cheaper than the 123 and a better range of curves to suit the A Series Engine;-
https://www.minispar...|Back to search
Or, if you wanted a replacement Distributor, I'm fairly sure this would have the same curve as original;-
http://holden.co.uk/...New&pCode=41419
#6 Supersouthward87
Supersouthward87
  • 33 posts
Posted 09 January 2015 - 08:55 AM
The blackbox and holden look quite interesting, especially as I'm not entirely sure what engine I have. I'm sure there is an engine identification thread here, I might go trawl through that
I know it's a silver seal 1275 and that's about it... Also seems to have Bosch super 4 spark plugs, definitely important (or not)
#7 Ethel
  • 26,029 posts
Posted 09 January 2015 - 10:32 AM
The block in Guesswork's picture is an A Series, see the long alternator bracket because it was originally cast for a dynamo. A+ has the bolt holes above the oil filter. Silver Seal just means it's a factory reconditioned unit.
I wouldn't get too bogged down finding an exact match, jut a stage 1 kit will alter the advance requirements. Even if it's totally original, the petrol you put in it isn't.
#8 Leonrjohnson
Leonrjohnson
  • 166 posts
  • Local Club: MOCQ Far North
Posted 12 January 2015 - 08:09 PM
I have one of these on my 970: works great :
https://www.minispar...px|Back to shop
