please Help. Iv put a LBC 3 branch manifold on my mini mpi but there is a rubber pipe touching and burning on the manifold on the left side of the manifold. The pipe comes out of a sensor and goes into the throttle body. Desperate to sort out ASAP any idea?
Thanks James
Mpi Lbc Exhaust Manifold Help
James Harris
, Jan 08 2015 08:39 PM
4 replies to this topic
Posted 08 January 2015 - 08:39 PM
Posted 08 January 2015 - 08:41 PM
When I had this set up I had the same issue, I cut about 10mm off the end that enters the sensor on the inlet gave a bit more clearence
Posted 08 January 2015 - 09:55 PM
Ok thanks anyone know where I can get a new pipe/hose as its already burnt a hole in it?
Thanks for the reply
