Su Carb Cleaning
5 replies to this topic
#1 Chas campen
Chas campen
  • 49 posts
Posted 09 January 2015 - 08:27 PM
Hi, anyone know of a good guide to cleaning an su carb .... Think I've got some crud in min :-/
#2 Yams
Yams
  • 644 posts
Posted 09 January 2015 - 09:16 PM
If it's a single HS4 carb then buy yourself a fresh gasket kit A new jet and float needle. I cleaned mine by simply taking it off the manifold, taking the lid off the float chamber and cleaning inside, new needle and float also, then cleaned the main throttle-body, replaced the jet, re-oiled the dashpot and re-assembled. Takes around an hour max, if you're fairly intuitive you'll be able to figure it out as you go along. If you do a goggle search there is probably an in-depth step by step guide out there however.
Edit: Use carb cleaner, its available off the shelf from motor part retailers.
Edited by Yams, 09 January 2015 - 09:17 PM.
#3 Chas campen
Chas campen
  • 49 posts
Posted 09 January 2015 - 10:27 PM
Think it's a HIF 38 ......
#4 Stu1961
Stu1961
  • 636 posts
  • Local Club: Still Looking
Posted 10 January 2015 - 12:33 AM
Loads of info on 'Burlen Fuels' web site
#5 Covert
Covert
  • 526 posts
Posted 10 January 2015 - 09:27 AM
Send them to me for ultrasonic cleaning. ..
#6 Chas campen
Chas campen
  • 49 posts
Posted 10 January 2015 - 05:39 PM
I've done it :-) there was a little filter behind the float valve assemble, was pretty bad lol ... Changed the air cleaner also minging lol
Then had to richer the mixture by a turn and a half, and I have myself a little red rocket :-)
Edited by Chas campen, 10 January 2015 - 05:41 PM.
