Best Way To Remove Old Underseal?
Posted 09 January 2015 - 09:52 PM
I thought a wire cup brush would knock it off, no problem. But not to be, any tips would be appreciated
Jim
Posted 09 January 2015 - 10:04 PM
Posted 09 January 2015 - 10:12 PM
Sharp wood chisel, not heat.
Posted 09 January 2015 - 10:23 PM
I use paint thinner or brake clean and a scraper( 2 wall paper scrapers but ive cut one down to 1 inch) very effective
Posted 10 January 2015 - 04:54 PM
Posted 10 January 2015 - 07:35 PM
can be a bit more messy but can make it easier to scrape off, Depending on the type you have, I found it easy without heat.
Posted 10 January 2015 - 07:44 PM
Posted 10 January 2015 - 07:55 PM
Get someone else to do it .
I use gunwash & a scraper
Posted 10 January 2015 - 08:20 PM
I prefer thinners to white spirit, keeps silicons to a minimum for any painting/priming etc that will follow.
Posted 10 January 2015 - 09:11 PM
You get someone else to use gun wash and a scraper!
Posted 11 January 2015 - 12:06 AM
My floors were the original greeny colour primer followed by a thin coat of black underseal which had gone crispy and flaky so it just scraped off with a scraper and then washed it down with thinners so i guess i was lucky.
In your case, i would gently warm it with a heat gun and scrape it off then wash it down with thinners afterwards.
It is a long winded and dirty job, you just have to be patient to get the best results.
Good luck
Ben
