Plug Gap
14 replies to this topic
#1 racingbob
racingbob
  • 3,061 posts
Posted 10 January 2015 - 05:43 PM
I read somewhere guy sets plugs at 50 thou
with electronic ignition
I got lucas electronic and run 35
any comments
#2 cal844
cal844
  • 9,672 posts
  • Local Club: TFMOC
Posted 10 January 2015 - 06:56 PM
I run them as they come out the box!
#3 old original
old original
  • 353 posts
Posted 10 January 2015 - 10:10 PM
35 thou on a 65 dizzy here
#4 richmondclassicsnorthwales
  • 942 posts
Posted 21 January 2015 - 08:29 AM
I would run them at 25 really, keeps a tighter spark
#5 Anthony30
Anthony30
  • 1,467 posts
  • Local Club: N/A
Posted 21 January 2015 - 08:34 AM
No need to alter the plug gaps on multi-electrode or platinum tipped spark plugs.
#6 hellom8
hellom8
  • 188 posts
Posted 21 January 2015 - 10:40 AM
Don't change them out of the box.
#7 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,096 posts
  • Name: Neil
Posted 21 January 2015 - 10:50 AM
So for all those members who do not change them out of the box why?? The one thing you need to do is check them as they may not be set to the correct gap.
#8 Anthony30
Anthony30
  • 1,467 posts
  • Local Club: N/A
Posted 21 January 2015 - 11:16 AM
I check my spark plug gaps just to check, but platinum tipped and multi-electrode plugs should not need setting.
#9 spiguy
spiguy
  • 1,537 posts
Posted 21 January 2015 - 11:24 AM
I used to check them diligently every time with feelers, but never found one that was 'wrong'. Seems to me that the old fingernail test is close so I just do that in case something is wildly off.
#10 sonikk4
sonikk4
  • 16,096 posts
  • Name: Neil
Posted 21 January 2015 - 11:32 AM
It always pays to never take something for granted. For a couple of minutes checking you will know then on single electrode plugs the gaps are good.
#11 Anthony30
Anthony30
  • 1,467 posts
  • Local Club: N/A
Posted 21 January 2015 - 11:44 AM
Has anyone else tried the Bosch multi-electrode spark plugs? They cost a fortune, compared to NGK, and made my car run  :xxx: compared to NGK platinum tipped plugs, and the NGK plugs last longer. I bought them out of curiosity really, thinking they might make the car run slightly better. I was obviously wrong. >_<
:bah:
#12 hellom8
hellom8
  • 188 posts
Posted 21 January 2015 - 12:00 PM
I give them a check before putting them in, incase they have move in transit.
#13 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 21 January 2015 - 01:03 PM
+1 to Sonikk4's comments.
Until relatively recently pre-gapped plugs were not common.  You checked and set new plugs to be correct for your application.  The same plugs (typically Champion N9Y through the 1960s and '70s) were used in MANY British cars.  You could not assume that Champion was going to pre-gap them for your particular application.
Yes, modern cars often have pre-gapped plugs and in the case of NGK (and/or Denso) I believe a couple of digits at the end of the part number reflect the gap in millimeters.  So if you are going to buy pre-gapped plugs, make sure you buy the ones with the correct pre-gap or... check and set them as you won't otherwise know if they are set correctly for your engine.
Edited by dklawson, 21 January 2015 - 01:04 PM.
#14 newenglandmini
newenglandmini
  • 646 posts
Posted 11 February 2015 - 04:53 PM
My 1973 Mini 1000 Leyland owners manual and my 1976 Rover shop manual both stipulate a spark plug gap of .025" for my 998 cc engine.  My Haynes Mini manual (which purports to cover all Mini variants from 1969 to 2001) stipulates a gap of 0.8mm (.032").  Any idea why the Haynes manual has a different specification?
#15 Earwax
Earwax
  • 520 posts
Posted 11 February 2015 - 07:47 PM
newengland mini, no idea really, but typically 25 thous was for points system, whilst electronic dizzy versions(aftermarket) can utilise a larger gap (again typically 32 thous., but i have seen 35 thous... the coils in these systems MAY be different (resistance) so need to check this as well
