Front Bulkhead Replacement
1 reply to this topic
#1 CBJ805T
CBJ805T
  • 438 posts
Posted 11 January 2015 - 02:26 PM
Hi All,
I'm still trying to decide the best way forward for my Front Bulkhead. I'm considering replacing the whole assembly with this - http://www.somerford...m3m7u8T-YURaOh2
Both Inner wings also need replacing so if I replace the front bulkhead assembly I'd be doing so with only the Floor and dash-rails in place. I've got the car braced to pick up in the bottom front sub mounts, but my questions is how to ensure I get the entire assembly in the correct position.
I could mount the lower front mounts the the bracing and clamp the bottom of the toe-board to the floor pan, how would you pick-up on the top sub mounts? (do i need to?).
the problem is this assembly is for post-1990 cars, and doesn't have the large central hole in it, so I'll have to remove the car from the spit - which ordinarily I could have used to make a jig to locate on to the top sub mounts.
I hope all that makes sense
Any thoughts?
#2 Tupers
Tupers
  • 4,158 posts
Posted 11 January 2015 - 03:14 PM
Check out Tom's van rebuild. Clicky
A fully bulkhead replacement really isn't something you can do without the shell on a jig of some sort.
