Sheet Metal Folder
11 replies to this topic
#1 CBJ805T
CBJ805T
  • 438 posts
Posted 12 January 2015 - 05:04 PM
Hi All,
Has anyone got one of these? If so, any good?
If you don't how do you go about folding sheet steel?
Chris
#2 greenwheels
greenwheels
  • 689 posts
  • Local Club: Mini Fixers
Posted 12 January 2015 - 06:08 PM
I clamp the sheet between two lengths of angle iron in a vice and then bend it over with the help of a rubber mallet.
#3 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,042 posts
Posted 12 January 2015 - 06:38 PM
As above stick it in the vice, if the metal is longer than the vice jaws, clamp the angle iron together.
#4 cookie4343
cookie4343
    **Caution: Do Not Feed Alcohol**
  • 2,257 posts
  • Local Club: CV1 Mini's
I made my own for around £20, it does need improvement but does the job it's shown here in this thread in the link below.
http://www.theminifo...ips-and-tricks/
#5 CBJ805T
CBJ805T
  • 438 posts
Posted 12 January 2015 - 07:35 PM
Sorry guys, just realised I didn't paste the link. For £36 I thought it might be worth a look.
http://www.stakesys....t_metal_folder/
Edited by CBJ805T, 12 January 2015 - 07:36 PM.
#6 acrowot
acrowot
  • 278 posts
  • Local Club: manchester minis
Posted 12 January 2015 - 07:55 PM
ive got one think its really good think u can get them off ebay cheaper than that
#7 castafiore
castafiore
  • 116 posts
Posted 12 January 2015 - 08:29 PM
Have a look on Readers Rides forum - the Making Panels thread by bmwtony has some great metal fabrication techniques. He includes plans and explanation of how to make your own metal folder.
Sorry can't do a link on this phone.
Edited by castafiore, 12 January 2015 - 08:30 PM.
#8 One step at a time
One step at a time
  • 282 posts
Posted 12 January 2015 - 09:43 PM
Is there any chance of a few more pics from different angles and a little description on how you put it together.
#9 cookie4343
cookie4343
  • 2,257 posts
Posted 12 January 2015 - 10:13 PM
Is there any chance of a few more pics from different angles and a little description on how you put it together. http://www.theminifo...ips-and-tricks/
No probs I'll try get some tomorrow, makeing the hinges was the hardest part but not that bad after thinking about it.
#10 cookie4343
cookie4343
  • 2,257 posts
Posted 12 January 2015 - 10:45 PM
I bought this steel tube to make the hinges, I cut it into 6 pieces.
4 pieces at 10mm and 2 pieces at 20mm 3 pieces for each hinge, 1 10mm then 1 20mm then another 10mm made 1 hinge.
http://www.ebay.co.u...=item3a8deaa446
I used this steel bar 6mm in diameter as hinge pins and it fitted inside the bar above to make a solid hinge.
http://www.ebay.co.u...var=&hash=item0
Then I bought this angle in 600mm lengths x3
http://www.ebay.co.uk/itm/291080269892
I'll try explain with some pics better tomorrow, if I was to make one again I'd make a few changes but it does the job.
#11 CBJ805T
CBJ805T
  • 438 posts
Posted 13 January 2015 - 12:39 PM
Thanks Castafiore, what would we do without Google?
This thread is worth a look for those not experienced with panel bashing - like myself!
http://retrorides.pr...ad/70135/panels
#12 ibrooks
ibrooks
  • 1,017 posts
Posted 13 January 2015 - 12:44 PM
For the size and capacity of that one I'd not bother. I either clamp stuff between two bits of angle in the vice or for larger stuff I lay it flat on a bench with a piece of angle over the edge to fold over and clamp another bit of angle or square section on the top of the fold and then set to with a hammer/mallet.
I am debating buying one but a somewhat heavier one that'll do thicker material. I just need to ask myself how often I bend heavier stuff to justify it.
Iain
