Dpf Removal - & Mot Reg's
13 replies to this topic
#1 sledgehammer
sledgehammer
  • 3,109 posts
Posted 12 January 2015 - 05:29 PM
Am I reading this right ???
a lot of people are having problems with DPF's blocking up
http://www.motester....val-and-the-mot
a DPF isn't required to pass the test - as long as the exhaust emissions are within limits ???
#2 nicklouse
  • 18,742 posts
Posted 12 January 2015 - 05:31 PM
If originally a DPF is required to be seen fitted. Same as a CAT. if they were there originally they mudt pass a visual check.
This is for both Diesel and Petrol engines. But no dpf on a petrol of cause.
https://www.gov.uk/g...ticulate-filter
Edited by nicklouse, 12 January 2015 - 05:33 PM.
#3 Carlos W
Carlos W
  • 10,114 posts
Posted 12 January 2015 - 05:32 PM
My car has nothing inside the dpf, the innards were smashed out. When the dpf was programmed out the dpf light comes on with all the other dash lights but then goes off.
I had no problem with the mot.
#4 MiniJosh92
MiniJosh92
  • 1,709 posts
Posted 12 January 2015 - 05:42 PM
To quote from the MOT testers guide, "Reason for rejection - A catalytic converter or particulate filter missing where one was fitted as standard", updated Feb 2014.
#5 SiZT
SiZT
  • 50 posts
Posted 12 January 2015 - 05:43 PM
This
So you need to do the above if you want rid of the dpf, it depends on how many miles you do and the types of journey
#6 Carlos W
Carlos W
  • 10,114 posts
Posted 12 January 2015 - 05:45 PM
You cannot visually tell mine hasn't got a DPF, no cutting and welding.
#7 grumpy2
grumpy2
  • 613 posts
  • Local Club: Wirral Minis
Posted 12 January 2015 - 05:47 PM
looked into this with my dodgy old diesel
yes, if you remove the DPF entirely it SHOULD fail an MOT. If you remove the innards of the DPF and refit the carcase then unless the tester can tell it has no innards it may well pass an MOT if the ecu has been programmed to extinguish the warning light.
However if there are any subsequent engine management related issues then you have minimal chance of the diagnostic software accurately pinpointing the problem.
spawn of satan!
#8 Chance
Chance
  • 1,457 posts
In that case, if i smash the innards out of my CAT, or buy one of those decat pipes that looks like a CAT will it pass an MOT if the emissions are OK?
#9 Tanya
Tanya
    Snuggle-Buddy
  • 1,334 posts
Posted 12 January 2015 - 05:57 PM
+1 for me with this.
#10 SiZT
SiZT
  • 50 posts
Posted 12 January 2015 - 06:12 PM
spawn of satan!
Depends who's coded the light out and whether they've deleted all of the eml code or just those relating to the dpf
Yes, but the chances of it passing are minimal unless it's had a lot of time spent refining the idle and light load 2,500 - 3,000 rpm areas of the map
#11 Carlos W
Carlos W
  • 10,114 posts
Posted 12 January 2015 - 06:46 PM
Since I had my dpf removed and car re-mapped its quicker and more efficient. Its not at all smokey, I've asked people who've been following me
#12 grumpy2
grumpy2
  • 613 posts
Posted 12 January 2015 - 06:50 PM
Unlikely with what you have said.
A decat or DPF bypass pipe would be spotted easily, removing the DPF in nerds would not be so easy to spot but the tell tale light on the dashboard would be an automatic fail, oh and the light not illuminating with the ignition switched on should also be a fail.
It can be done and several companies offer a 'full service DPF removal' for about £300
I ended up having mine removed, ultra sonically and chemically cleaned and refitted. Only time will tell if this is a long term solution
#13 Mini 360
Mini 360
  • 4,933 posts
  • Local Club: Independent
Posted 12 January 2015 - 07:28 PM
Remap your car after you get it deleted.  Make sure they take into account the DPF delete and it will cause no issues, give you more power and torque and in some instances, better fuel economy.  Been doing a lot of research into doing all this to my future purchase MK4 Golf Anniversary GTI.
A lot of DPFs are hidden under engine covers.  Cant remove covers in an MOT test so you will be fine.  But to be honest as long as the emissions is fine, they won't fail you for it.  If they do, go to another MOT tester....
Edited by Mini 360, 12 January 2015 - 07:31 PM.
#14 cambiker71
cambiker71
  • 1,050 posts
  • Local Club: Cambscustomclassics.com
Posted 12 January 2015 - 08:12 PM
Dpf tell tale light is not an MOT fail, some dpf lights are on because it's due a regen but will still pass the emissions limits anyway. The lamp is not a testable item.
Who can tell if the innards are missing or if it's due a regen under MOT test conditions? Nobody, is the answer!
