Stopping Windows Misting Up Inside
32 replies to this topic
#1 pothole
pothole
  • 317 posts
Posted 14 January 2015 - 09:57 AM
Hi all I have an excellent tip to share with you to stop your mini windows misting up in side, get yourself a microfibre cloth apply some fairy liquid neat and smear on the windows, but don't rub it off. You will find it leaves a film on the windows and they will never mist up again. I have tried all sort, special cloths and sprays but have found  this method the cheapest and most effective so thought I would share to all those who don't lay up their mini for the winter months.
#2 matt050990
matt050990
    I have upside down nipples
  • 1,199 posts
  • Local Club: Currently Ridin' Solo :)
Posted 14 January 2015 - 09:59 AM
Does it leave a sticky residue on the glass? Does it affect the clarity?
#3 TMW.Racing
TMW.Racing
  • 248 posts
Posted 14 January 2015 - 10:04 AM
I use the rainex anti fog stuff - works pretty well but if you aren't very careful it will cause glare from oncoming headlights which is a slight safety risk....!
#4 nicklouse
  • 18,696 posts
Posted 14 January 2015 - 10:06 AM
old skool the use of soap it is the glycerin in the liquid soap that stops the misting.
but your best bet is to start of getting the carpets dry and keeping the water out.
#5 Steve220
Steve220
  • 5,067 posts
  • Local Club: BMC
Posted 14 January 2015 - 10:16 AM
RainX FTW
#6 lewBlew
lewBlew
    Previously known as theboybradley.
  • 1,238 posts
Posted 14 January 2015 - 10:17 AM
When you say don't rub it off, doesn't it leave a mess?
#7 pothole
pothole
  • 317 posts
Posted 14 January 2015 - 10:21 AM
It does leave a residue on the glass, thats why it works, it does not effect the clarity as its only used on the back and side windows, the so called heater should clear the windscreen, but the main thing its as cheap as chips, try it what do you have to lose
#8 mikep12
mikep12
  • 73 posts
Posted 14 January 2015 - 10:40 AM
Buy a Ford, oops tin hat on
#9 Steve220
Steve220
  • 5,067 posts
  • Local Club: BMC
Posted 14 January 2015 - 10:48 AM
Having soap on your window will attract dust and dirt residue which will build up. You'll try and clean in and it'll all smear, reducing visibility.
#10 coopdog
coopdog
  • 4,506 posts
Posted 14 January 2015 - 11:23 AM
Best one I've seen is filling old socks up with cat litter and leaving them around the car
#11 Ellie
Ellie
  • 298 posts
Posted 14 January 2015 - 11:28 AM
Clean the inside of the screen with shaving foam, try it tonight on the bathroom mirror.
My dad swears by this method.
#12 Dusky
Dusky
  • 5,322 posts
Posted 14 January 2015 - 11:36 AM
Thats why you have the windscreen heater.. so you can have 2 patches of 20x 20 centimeters to look through  :bah:
#13 Steve220
Steve220
  • 5,067 posts
  • Local Club: BMC
Posted 14 January 2015 - 11:42 AM
Or you could just carry a microfibre sponge and give the inside a wipe before you drive off.
Cat little idea works similar to silica gel packs, worth a go if your car is a long time sufferer of damp.
#14 pothole
pothole
  • 317 posts
Posted 14 January 2015 - 02:01 PM
And by having the soap already on the window a damp cloth will soon shift it, dust and dirt is never a problem in a mini in the winter the condensation settles it to the seats and carpet  :shifty:
#15 Tommyboy12
Tommyboy12
  • 2,255 posts
Posted 14 January 2015 - 02:55 PM
I couldnt live without the quick clear screen on my Mondeo!
I use one of those microfibre sponges for the windscreen in the Mini. I got a pack of 3 for £1 from Lidl. Cracking the window open slighlty helps as it draws in fresh air.
