Security Ideas For Minis
32 replies to this topic
#1 The Clubby Hubby
The Clubby Hubby
  • 555 posts
  • Local Club: Friends with minibitz
Posted 14 January 2015 - 08:40 PM
Attached File  image.jpg   59.72K   96 downloads
Saw this today it looks like a mini in a cage would take a while for those scummy people to steal this one got me thinking out of the box of more ideas making them harder to steal
#2 Italianjob
Italianjob
  • 215 posts
  • Local Club: Not a member yet.
Posted 14 January 2015 - 09:06 PM
It would take less than two minutes to get that mini out of that cage. If someone wants to steal it chances are they will.
#3 The Clubby Hubby
The Clubby Hubby
  • 555 posts
Posted 14 January 2015 - 09:10 PM
I'm aware of that but it's two more minutes to catch them and lock them in a cupboard 😄
#4 Tupers
Tupers
  • 4,156 posts
Posted 14 January 2015 - 09:12 PM
I know someone who welded a massive steel loop made from 15MM solid bar to their rear subframe and chained the car to another loop cast into their driveway.
It couldn't be driven or lifted away while chained and cutting the chain would have made a hell of a racket.
#5 Black.Ghost
Black.Ghost
    Formerly known as TneMini.
  • 2,567 posts
Posted 14 January 2015 - 09:19 PM
That's ok, just drop the rear subframe off.
No security measures are 100%. All measures are only ever designed to delay someone enough or inform someone that something is happening.
#6 DFulton
DFulton
  • 158 posts
Posted 14 January 2015 - 09:36 PM
When I first started as a student, we were given a note on securing bikes by the local police.  They had an evaluation of all the standard locks on the market and the approximate time it would take a thief to get through them.  The times ranged from <10secs to 5-10 minutes (for the top of the range D-locks).  It's all just about delaying, or possibly making another car look like a better prospect.
#7 cal844
cal844
  • 9,645 posts
  • Local Club: TFMOC
Posted 14 January 2015 - 09:39 PM
I have a stoplock and autolock
Stoplock : http://www.halfords....ring-wheel-lock
And the Auto lock(gear stick to hand brake lock)::http://www.amazon.co...k/dp/B000X5S8LU
#8 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 14 January 2015 - 09:42 PM
very true, if it's too hard they will give up and find another one. The best way is to make sure as much as possible they don't know where it is to start with. A baby alarm works brilliantly as if they so much as fart you will know about it. A cheap shed alarm left on the back seat is also good as they won't go off when the door is opened (which is what they look for with a car alarm) then goes off when they sit in. Alarms are ignored so anything that is loud to the point of annoying is better. Neighbours might not bother about a car alarm but if there is a fire bell that is disturbing them watching deadenders then you have more of a chance.
#9 Dusky
Dusky
  • 5,322 posts
Posted 14 January 2015 - 11:23 PM
Dogs, absolutely amazing at keeping any burglar out. We've 2 a dalmatian and a very mad dobermann. Be lieve me, when the dovermann bites you december how stupid it was to try and steal something here...
More easier things are some 'hard' measures like taking the steering wheel off, and 1 of my favorite is to connect the horn to the coil or starter circuit, quite funny trick to play on your Friends too ;) dropping a heavy little lead bar in the dashpot stops them from starting
#10 mab01uk
mab01uk
  • 12,538 posts
Posted 14 January 2015 - 11:34 PM
Manual in line fuel stop/cut off tap:-
http://www.demon-twe.../fuel-line-taps
#11 Cooperman
  • 23,326 posts
Posted 14 January 2015 - 11:47 PM
If an electric fuel pump is fitted, a hidden switch in the power feed to the pump is ideal. The engine will start, then just stop a short way down the road and a thief won't want to be seen at the roadside trying to get it to start again. But the switch must be either well hidden or well disguised.
#12 maryquant
maryquant
  • 932 posts
  • Local Club: minidesigner.co.uk
Posted 14 January 2015 - 11:52 PM
I have been thinking about this a lot lately too, and want something pretty secure for our cars but the way I see it there are two scenarios:
a) It will be stolen by professionals to ring/steal bits off etc or
b) It will be stolen for a joy ride and eventually a BBQ
In both of these scenarios physical deterrants will only slow them down, loud sirens may well scare them off and each "security" device will present a different problem for the differnt type of theif (a wheel lock wont make any difference to someone lifting it onto a truck for example.)
If someone wants it, they will have it, and so I would spend my main chunk of money on speedy recovery, hidden GPS, car tracking systems, something that can help find the vehicle quietly whilst the theif is unaware. Have looked into automatic fireextinguishers too which could save a bunch of heartache if things took a turn for the worse.
#13 mab01uk
mab01uk
  • 12,538 posts
Posted 15 January 2015 - 12:09 AM
CHIPnTRAC GPS tracker was featured in several car magazines last year, it has a one off cost of £149 and is popular with classic car owners for diy installation.
More details here:
http://www.rbs-prope...tracker_50.html
#14 Mini Waco
Mini Waco
  • 438 posts
Posted 15 January 2015 - 12:19 AM
Completely naive here, but how are the mini's stolen so easily?  Are they easily hot wired w/o keys.  Easily broken into?  What makes them such a magnet for theft?
#15 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
I am not a fan of visible anti theft devices as they can make the car more appealing to a thief.
I used to have a lock up in a lot behind some houses and my first thought was to put lots of locks on the door which i did and someone broke in 2 days later.
after that, i just replaced the broken locks with one and had no trouble again.
Thing is with a car, chaining it down is not really practical if you have to park on the street etc.
I heard a story about someone who left their car on the drive with another car in front of it to stop someone nicking it while they were away and the thief hi-ab'd the car over the top of the one blocking it in.
My mum had her car stolen from the side of the motorway after a breakdown. The bardards winched it onto a flat bed and that was that. Mum found witnesses but they didn't take any details because they just thought it was being recovered!
All you can do really these days is have a decent steering lock and one for the handbrake/gear stick and if you can, lock it up in a garage.
