Interior Lights Stay On
Posted 16 January 2015 - 09:28 PM
I recently swapped my interior lighting for brighter LED units.
Ever since doing this they seem to stay on.
When the door shuts they dim right down but never seem to be 100% off.
I have played with the door switches but doesn't seem to make a difference.
Is there something obvious that could cause this?
Would it be a massive drain on the battery if left?
Much ta
Matt
Posted 16 January 2015 - 09:33 PM
Pull the casing out and check the connections and switch.
It will seriously drain it.
Posted 16 January 2015 - 09:52 PM
Joys.
Posted 16 January 2015 - 09:57 PM
Posted 16 January 2015 - 10:30 PM
When you changed the bulb did you snag any wires against the metal body?
Posted 16 January 2015 - 10:32 PM
Posted 16 January 2015 - 10:36 PM
Stick the old bulb back in if you can, the wireing needs to be changed for LEDs don't they? If it goes off then you know it's the led if not then some wiring fault.
Posted 16 January 2015 - 10:43 PM
Yes, most LEDs only need 0.7 volts to power them.
But it does sound like a live wire fault
Posted 16 January 2015 - 11:14 PM
All the ceiling lighting in my house is LED and, when they're off, they still appear to have a blue glow if you look directly into them. I even went into the loft to make sure I hadn't left a light on up there that was somehow shining through but there wasn't. I think it's just what (some) LEDs do ...
Posted 17 January 2015 - 07:27 AM
I'll pop into the garage this morning going to see if they are still lightly glowing in a bit.
Much ta for the responses.
Posted 17 January 2015 - 08:41 AM
Went out this morning to check, Lights are still on very dim.
The odd thing is that only 1 stays on even though they are both off the same wiring.
Will have a fiddle when I get time and update.....
Posted 17 January 2015 - 08:52 AM
Posted 17 January 2015 - 08:48 PM
I would suspect that the most likely fault area would be damp in the door switches. If you can pull them out and disconnect does the LED still stay on?
Edited by Rog46, 17 January 2015 - 08:49 PM.
Posted 17 January 2015 - 09:32 PM
Most likely a bit of capacitive coupling because the leds take so little to light them, a resistor in the 12v feed wire would sort it, its common on all leds including the ones in your home.
Posted 17 January 2015 - 10:35 PM
LEDs usually need about 1.7 to 2V for red or green. Blue ones can need as much as 3.5V.
A regular silicon diode will have a volt drop of about 0.7V
Paul.
Edited by PaulColeman, 17 January 2015 - 10:35 PM.
