I know this has been covered before and I have had a look at the answers but here goes. This is on a track mini, build from a bare shell. So the wiring loom is a one off based on a 76 mini wiring diagram. The fault is the usual gauge does not move at all when the mini should be at normal temp. If you put the sender wire to earth then the gauge slowly goes off the end of the reading. I am running a voltage stabilizer made for me and it is a Smiths gauge, this is the second sender I have used and here is a list of what it is compatible with.
Mini Clubman 1000 1970-82
Mini Clubman 1100 , 1275 GT 1969-80
Mini 850 1970-80
Mini 1000 1970-92
Mini 1100 1976-80
Mini Cooper 1275 , 1.3i 1990>>
Mini Cooper S 1275 1970-71
Mini Cooper Si 1992>>
Mini ERA 1989>>
Any answer gratefully received. ![]()
