Seam Sealer
14 replies to this topic
#1 acky
acky
  • 84 posts
Posted 19 January 2015 - 07:48 AM
What can you use to replicate the sealer you find round the seams of the car
#2 stickycreambun
stickycreambun
  • 1,865 posts
Posted 19 January 2015 - 09:35 AM
Seam sealer, either brush on from a tin or mastic gun tube. I have a ton of upol one, perfectly good, you can geta nice eedge by using masking tape same as decorating.
#3 F1L8EY
F1L8EY
  • 600 posts
Posted 19 January 2015 - 09:38 AM
http://www.ebay.co.u...ff14=108&ff19=0
search the forum but I'm sure people just use seam sealer like this on from upol
#4 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,080 posts
  • Name: Neil
Posted 19 January 2015 - 09:49 AM
There are various sealants out there. Upol is good along with tiger seal etc. DO NOT use any silicon based product.
If you can get your hands on it Proseal aircraft sem kits. PS870B2 or B 1/2. This has a temperature range of -50 to something like +60. Over paintable, oil proof ( hydraulic and engine oil) and of course flexible. Once on its a complete sod to remove if applied correctly.
#5 One step at a time
One step at a time
  • 282 posts
Posted 19 January 2015 - 10:08 AM
Double post.
Edited by One step at a time, 19 January 2015 - 10:09 AM.
#6 One step at a time
One step at a time
  • 282 posts
There's one call Tiger seal. Comes in a tube it's flexible and you can over paint it.
#7 F1L8EY
F1L8EY
  • 600 posts
Posted 19 January 2015 - 10:35 AM
there is another product to remove aircraft PRC... ill dig out the product code for you tomorrow. its the only thing that works. that or rubbing it down for weeks with scotchbrite. I was thinking of using PRC as well. b1/2 refers to the time it takes to cure. you can get b2 (2 hours) and b12 which both give you a bit more time to work with if your not in  a rush :D
#8 OhDear
OhDear
  • 560 posts
Posted 19 January 2015 - 10:54 AM
Halfords do a tin for 16. Does what's needed I find it OK
#9 1984mini25
1984mini25
  • 8,785 posts
Posted 19 January 2015 - 01:23 PM
I've found the upol grey strip stuff that you brush on not only isn't smell friendly, but also dries out and crack with age. Instead I've been using a sealant similar to tiger seal but much cheaper. http://www.ebay.co.u...=item20d0960fe4
#10 sonikk4
sonikk4
  • 16,080 posts
  • Name: Neil
Posted 19 January 2015 - 02:00 PM
The numbers refer to the working time so 2 hrs for B2 and 1/2 hour for B1/2. The cure time is considerably longer. It all depends on heat and humidity.
#11 F1L8EY
F1L8EY
  • 600 posts
Posted 19 January 2015 - 02:09 PM
Potato potato ;) (that doesn't look right in text but it would if you said them differently) haha, have you used it in a automotive environment ??
#12 sonikk4
sonikk4
  • 16,080 posts
  • Name: Neil
Posted 19 January 2015 - 03:18 PM
Yes i have, my clubby has it on the wings to scuttle gap and under the inner wing to wing gap. My lads mini is completely sealed with it and the Mini i have just done a body resto on has it as well. I have used it on other cars as well.
#13 F1L8EY
F1L8EY
  • 600 posts
Posted 19 January 2015 - 07:17 PM
Nice, will pick some up then... i thought also of using JC5A for assemblies when they are bolted to things like the servo bolted to the bulkhead as a corrosion
inhibitor what do you think ?? Obviously in aircraft there are very few metal to metal dry assemblies...
#14 sonikk4
sonikk4
  • 16,080 posts
  • Name: Neil
Posted 19 January 2015 - 07:58 PM
Ahh nastinox, yep it should work well especially on things like subframe mounts like the heelboard. I use Nickel Never Seez on exhaust manifold bolts and studs.
#15 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 19 January 2015 - 08:20 PM
and dont forget to etch prime before you seam seal
