Calibrating Smiths Speedometer
14 replies to this topic
#1 minikev84
minikev84
  • 200 posts
  • Local Club: TVMC
Posted 20 January 2015 - 01:36 PM
Hello everyone, do you know someone who can calibrate a Smiths speedometer? Any names or company's will be good, thank you.
#2 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 20 January 2015 - 01:42 PM
Speedy Cables
#3 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 20 January 2015 - 05:59 PM
Why do you need to calibrate the speedo ?
#4 Jukesr
Jukesr
  • 67 posts
Posted 20 January 2015 - 06:16 PM
Arrrrmm so you no how fast your going !!! :)
#5 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 20 January 2015 - 06:20 PM
No, that's the answer to the question...
Why do you need a speedo ?
which is not the question I asked !!
#6 minikev84
minikev84
  • 200 posts
  • Local Club: TVMC
Posted 20 January 2015 - 06:31 PM
I should have done it 5 years ago, nothing on the car is original. Some times it's handy to have a speedo and its adding miles to the engine. When you're doing 80mph on the satnav and the speedo is reading 130mph+ its some what out.
#7 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 20 January 2015 - 06:52 PM
What speedometer are you using, is it a standard mini one or something else...
Quite simply you can calibrate the speedo, or you can change the rate at which the cable spins, by changing the speedo drives in the gearbox.
#8 minikev84
minikev84
  • 200 posts
  • Local Club: TVMC
Posted 20 January 2015 - 07:39 PM
It's 100mm of the shelf smiths 0-140mph speedo and I belive I'm using a cooper s cable. The engine is a 1340cc the diff is 3:10 and the wheels are 13"
#9 1968andyf
1968andyf
  • 146 posts
Posted 20 January 2015 - 08:11 PM
If you look down at the bottom could be slightly obscured by the bezel there will be a 4 figure number this is the turns per mile give speedy cables a ring and give them diff wheel combo and they will tell you what the figure should be if its a lot out send it to them for calibration if not check your speedo drive pinion matches your diff
#10 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 20 January 2015 - 08:16 PM
OK, so the speedo will be 1000tpm as that's what most off the shelf speedo's are...
Put a 5 tooth worm and 16 tooth pinion in and the speedo will be bob on..
#11 minikev84
minikev84
  • 200 posts
  • Local Club: TVMC
Posted 20 January 2015 - 11:29 PM
Ok thanks, is that what I should/could do or am I going to get better results if I have it calibrated.
#12 Craig89
Craig89
  • 600 posts
Posted 21 January 2015 - 07:08 AM
Do as guess-works has advised and you will be as good as it gets. Having a speedo recalibrate will cost a lot more money for nothing
#13 Dusky
Dusky
  • 5,322 posts
Posted 21 January 2015 - 07:33 AM
Can the speedo pinion be changed in situ?
#14 Spider
  • 15,209 posts
Posted 21 January 2015 - 07:48 AM
Yeap. Pull the radiator out.
#15 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 21 January 2015 - 08:00 AM
You can also change the worm drive in situ, but does require the removal of the engine mount and bracketry ( plus the radiator obviously )
