Best Tuning Method
18 replies to this topic
#1 Kieranlee999
Kieranlee999
  • 1,401 posts
Posted 20 January 2015 - 08:12 PM
At the minute the mini is running worse than a bag of spanners. What is the best way to set it up so it runs good at night with the lights and in day time?
#2 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 20 January 2015 - 08:24 PM
Check the battery voltage under load, then do a full service and check over, replacing where neccessary, what is the timing set to?!
What like is the tension on the fan belt?!
Edited by cal844, 20 January 2015 - 08:25 PM.
#3 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 20 January 2015 - 08:31 PM
Have you run through a full engine tune? you make reference to day and night running ? whats the difference
#4 Kieranlee999
Kieranlee999
  • 1,401 posts
Posted 20 January 2015 - 08:42 PM
in the day when i dont have lights on the idle is higher but with lights on it is lower.
Battery voltage is fine. Just had a full service near enough. how od i check what the timing is set too and the fan belt should be set up right.
#5 Kieranlee999
Kieranlee999
  • 1,401 posts
Posted 20 January 2015 - 09:25 PM
how much would a timing light help? do they work properly on a mini?
#6 nicklouse
  • 18,998 posts
Posted 20 January 2015 - 09:30 PM
If you have a lower idle with the lights on then your alternator is having to do a lot of work.
Get the battery checked or just put it on charge.
#7 Kieranlee999
Kieranlee999
  • 1,401 posts
Posted 20 January 2015 - 09:48 PM
it should be good the battery its brand new.
#8 nicklouse
  • 18,998 posts
Posted 20 January 2015 - 09:52 PM
And? You have never bought something that was faulty?
Have it and your charging system checked.
If you have lots of electrics you might need either a bigger battery or alternator or both.
#9 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 20 January 2015 - 10:03 PM
+1
#10 Kieranlee999
Kieranlee999
  • 1,401 posts
Posted 20 January 2015 - 10:07 PM
good point ill investigate at the weekend :P im also thinking of getting a timing light and having a play around with one of them as well.
#11 Anthony30
Anthony30
  • 1,467 posts
  • Local Club: N/A
Posted 20 January 2015 - 10:09 PM
As a guide, you will need a timing light, co meter, feeler gauges and some hand tools to tune your car to a reasonable standard. IMO.
#12 nicklouse
  • 18,998 posts
Posted 20 January 2015 - 10:10 PM
But if your timing is right then it is right.
The only difference is the load on the alternator.
Yep when I had the spots on and the heater on full I would have to pull the choke out a tad at junctions just to make sure it did not stall.
Oh the days of 12 car events around Yorkshire.
#13 Anthony30
Anthony30
  • 1,467 posts
  • Local Club: N/A
Posted 20 January 2015 - 10:16 PM
Halfords sell timing lights, or you can buy a fancy Snap-on one off ebay, if that's your thing. :D
#14 Anthony30
Anthony30
  • 1,467 posts
  • Local Club: N/A
Posted 20 January 2015 - 10:18 PM
Still need buy a 70 amp alternator and bigger battery for mine. :shy:
#15 Kieranlee999
Kieranlee999
  • 1,401 posts
Posted 20 January 2015 - 10:29 PM
can you send the halfords link please i cant find it :)
hehe mines a 70 amp
