why 1293?
Posted 12 July 2006 - 07:27 PM
Posted 12 July 2006 - 07:30 PM
1293 is 20 thou over standard.
1302 is 30 thou
1310 is 40 thou
1330 is 60 thou
1380 is not classed as a standard overbore size not usre what it is but it is a 73.5 mm bore
Posted 12 July 2006 - 07:39 PM
Posted 12 July 2006 - 07:46 PM
more cc's generally means more power
thing is most people wil probs upgrade other stuff when they get an engine rebore
Posted 12 July 2006 - 08:40 PM
Posted 12 July 2006 - 08:50 PM
Posted 12 July 2006 - 08:52 PM
Posted 12 July 2006 - 08:58 PM
Posted 12 July 2006 - 09:04 PM
could be 1330.
but i think 1302 is more likely on a non A+ as it was used more in the past
Posted 13 July 2006 - 12:11 AM
well when the bores wear out they can be overbored and larger pistons used.
1302 is 30 thou
1310 is 40 thou
1330 is 60 thou
1399 is 74mm bore
Odd number over sizes are pretty much unavailable now, its just the +20, +40, +60 and 73.5mm that are available now
Edited by Mini Sprocket, 13 July 2006 - 12:14 AM.
Posted 13 July 2006 - 07:32 AM
One other thin increasing the bore does, is increase the compression ratio ( given that every thing else stays the same ) this small but significant change will improve the bang as well !
Posted 13 July 2006 - 07:52 AM
in the oldern days +30 was a fairly popular bore, but as said above difficult to get hold of nowadays...
Can an old newbie come in here? The real reason 1293 was popular was down to competition in the '60s, where there were classes based on engine size. Under 1300cc was such a class, and attracted other cars e.g. Ford Escorts, Cortinas, Vauxhalls, and everyone was getting every last cc possible to get just under the class limit. There were even some 'funny' bore sizes using specially made pistons that yielded 1298cc.
The same was true of the 970S......that engine was *bred* for racing in the under 1000cc class, and was popularly bored to 999cc PERFECT. Also that engine was able to rev higher than any other A series due to the short crank throw, relative to the bore size (known in old parlance as 'square' or 'over square').
Posted 13 July 2006 - 09:15 AM
